Spatial Conform set to "None" is making my video clips blurry?
Heath Alseike
on Apr 22, 2015 at 10:52:50 pm
I shot a couple of interviews at a 1080 resolution. My client wants the final video in 720. When I drop the original 1080 clips into a 720 timeline with the spatial conform set to "none" so I can frame the interviewee a little closer and better the footage looks really blurry. The clip is not scaled up at all, no filters or adjustments yet. I can not figure out why this is happening. Can any one help or explain the issue. Please and Thank you.
Side not I did read a few other forms on similar problems however, they did not help. I rendered the video out and it was still blurry. I also tried the same thing in After Effects and it did not get blurry. I realize I can export if form After Effects and I am good, but that is way to time consuming.
Noah Kadner
Re: Spatial Conform set to "None" is making my video clips blurry?
on Apr 22, 2015 at 11:23:43 pm
Can you post a screenshot of your timeline and project settings?
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Craig Seeman
on Apr 23, 2015 at 2:01:46 am
I think there's a best performance, best quality setting which might have impact. Just a wild guess because it does bite a few people when they think there's a quality issue that shouldn't be there.
Bret Williams
on Apr 23, 2015 at 4:59:40 am
If it is a bug you could always try setting it to fit and scale it up 150%.
Scott Witthaus
on Apr 23, 2015 at 1:17:30 pm
As noted, the dropdown menu on the upper right of the viewer has options for Better Performance or Better Quality. Choose quality.
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
Jeff Kirkland
on Apr 23, 2015 at 1:32:18 pm
If it was the performance setting it shouldn't affect rendering but the OP says it rendered blurry. Maybe try a new project or library and see if it's just something weird with that particular timeline?
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Heath Alseike
on Apr 23, 2015 at 2:20:38 pm
Awesome, thank you everybody for helping me out. The quality was set to better. I ended up creating a new project and that did work. I don't know what was wrong with the first one but, good call and thank you Jeff. So simple.
Bret Williams
on Apr 23, 2015 at 11:34:53 pm
That setting only applies to playback. Rendered or otherwise. While paused you'll see full quality.
