Does FCPX Support .M2T format?
Ray Sherman
on Apr 12, 2015 at 8:48:41 pm
Hi, Like to know if FCPX supports AVCHD .M2T (not .M2TS) video natively? If not, could anyone please explain the best workaround for importing and/or transcoding? Thanks in advance for all your help. Ray
Tim Jones
Re: Does FCPX Support .M2T format?
on Apr 13, 2015 at 7:52:04 pm
FCP X 10.2 has new AVCHD support, and specs specifically call out M2T is one of the formats supported.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
Ray Sherman
on Apr 14, 2015 at 11:32:40 am
Thanks Tim.... That's awesome to hear! Although, I did look up the new update in which I didn't see support for .M2T, but then again at times, Apple doesn't always list everything:
https://itunes.apple.com/us/app/final-cut-pro/id424389933?mt=12
(Click on the word More under the Description for details)
I do see that it now supports Sony's XAVC format, assuming they now support the much needed XAVC-L (Long GOP). It has supported XAVC-S, but not XAVC-L. This would be great news for us Sony XDCAM PXW-X70 and similar camcorders. Thanks again for your input, Ray
Ray Sherman
on Apr 14, 2015 at 2:30:27 pm
But.... then again, in regards to XAVC-L, maybe not.
http://www.fcp.co/final-cut-pro/tutorials/1644-the-trick-to-import-sony-fs7...
http://www.hdwarrior.co.uk/2015/04/14/importing-sonys-xavc-footage-into-fcp...
