~~ Ideal iMac setup for After Effect and FCP
Jacky Kuk
on Apr 10, 2015 at 8:53:52 pm
I'm an amateur when it comes to computer setups.. hoping experts here can help me out.
99% of my work is to produce animated explanation video for my company.
I use After effect to compose my animations (most of them are flat, non-3D, animations of cartoon people) Then I export all of them onto FCPX for editing
Each project is 3mins long, in 1080p.
I'm trying to see what kind of set up I should have because right now these programs LAG LIKE CRAZY after 30 mins use.
I'm editing on my macbook pro and here are the specs:
Processor Name: Intel Core i7
Processor Speed: 2.6 GHz
Video Card: NVIDIA GeForce GT 650M (1024mb)
Memory: 8GB
HD: 500 GB SSD
I'm load all my AE onto my Lacie 7200RPM HDD and edit from there
Do I need to change anything? My friends are recommending the iMAC.... I have the budget but I don't want to spend if not necessary and they might announce new iMac soon?
Advise would be greatly appreciated :) thank you!
Noah Kadner
Re: ~~ Ideal iMac setup for After Effect and FCP
on Apr 11, 2015 at 6:05:50 am
Always get the most powerful Mac you can afford. Updates always come.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Charlie Austin
on Apr 11, 2015 at 7:25:40 pm
[Noah Kadner] "Always get the most powerful Mac you can afford. Updates always come."
Yep... it's the hardware Catch 22. As soon as you buy a computer, a new version appears. ;-) I usually wait for the new version, and then buy the "old" one. usually at a discount. :-)
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Bret Williams
on Apr 13, 2015 at 12:26:58 pm
You don't have any memory. 8GB is really a bare minimum to be opening AE and FCPX. Both programs use RAM extensively for caching assets as you go along. I'd start with maxing out the RAM.
Jacky Kuk
on Apr 13, 2015 at 7:47:34 pm
Thank you guys,
Do you think adding JUST ram will be enough?
If not then I might get iMac and use my macbook as 2nd render machine to double the efficiency for myself
Bret Williams
on Apr 13, 2015 at 8:04:50 pm
I guess it could work as a second machine. If you put more RAM in it. :)
And give 10.2 a try. RAM leaks and sluggishness is supposed to be a thing of the past. But honestly I can't imagine trying to use AE with 8 gigs. I'm doing corporate stuff in FCP, AE and motion. 32gigs doesn't seem like enough sometimes.
If you go iMac, get 32gigs RAM, i7, and the top GPU and you'll be a happy camper.
Jacky Kuk
on Apr 13, 2015 at 8:20:38 pm
Thank you for your replies,
I shall go negotiate with my business partner about paying half the expense now >:D
Bret Williams
on Apr 13, 2015 at 10:11:53 pm
So at my facility you just said " I'm going to go ask my wife for money." :)
Doug Metz
on Apr 14, 2015 at 4:46:54 pm
You may also want to consider Thunderbolt-connected storage... if you're using an older LaCie drive with USB 2.0 or FireWire800. Upgrading the bandwidth of your external storage will help quite a lot as well.
Doug Metz
Anode
