Ken Burns
James Ewart
Ken Burns
on Apr 10, 2015 at 3:28:38 pm
Hello
I wonder if somebody might enlighten me. I've got a bunch of stills, cut to music ... I guess you know the kind of thing. It is a bit cheesy. I'm sure I saw a tip from Bret sometime ago about how to smooth them out as they kind of jar to and end before the cut..
What can I do please to smooth those moves out a bit?
Many thanks
James
Mark Suszko
Re: Ken Burns
on Apr 10, 2015 at 5:59:59 pm
Change the interpolation setting to ease in/ease out, or manually make bezier curves. Keyword search those in the manual for details.
James Ewart
Re: Ken Burns
on Apr 11, 2015 at 2:51:45 am
Thanks for this. I just find ease in and ease out can still be rather jumpy. Wondered if there was another way.
I'll look into Bezier curves thanks
tony west
Re: Ken Burns
on Apr 13, 2015 at 3:14:32 am
James, I tend to overlap my clips so that the move is hidden in the dissolve. If that makes sense.
I want the move already in motion under the other clip so that when the transition occurs you miss that kind of rough start.
James Ewart
Re: Ken Burns
on Apr 13, 2015 at 10:22:48 am
Thanks. Trouble is I'm cutting!
The odd thing is it doesn't happen every time. Usually the default ease in ease out works fine but occasionally it jars. Little bitty bug in there maybe?
tony west
Re: Ken Burns
on Apr 13, 2015 at 12:02:02 pm
Does it kind of stutter a little?
What I have found is that if the file size of my still that I'm using is too large it won't be as smooth for me.
I don't have a new tube so I just chalked it up to that, but I'm not sure.
I have used a ton of pics on my doc and most have been fine.
James Ewart
Re: Ken Burns
on Apr 13, 2015 at 12:30:15 pm
Ahh that's a theory thanks i'll have a look into that.
Bret Williams
Re: Ken Burns
on Apr 13, 2015 at 12:31:35 pm
ate you using the ken burns controls? There is a plug called Ken Burns from FCP effects that I find invaluable for this stuff.
James Ewart
Re: Ken Burns
on Apr 13, 2015 at 12:34:01 pm
Thanks Bret didn't know about that I will look into it.
Wonder if I can use them after the fact. Job now completed but I'd love to smooth a couple of them up.
Bret Williams
Re: Ken Burns
on Apr 13, 2015 at 12:38:02 pm
Not really. They're basically preset moves. You can of course adjust them completely. But they give you a bunch of presets like zoom in and down. Pan up and right. Etc. and either with or without easing. I've found they work really well as is usually.
James Ewart
Re: Ken Burns
on Apr 13, 2015 at 12:46:19 pm
Yes really good I've watched the trailer on their site.
James Ewart
Re: Ken Burns
on Apr 15, 2015 at 12:57:51 am
This behaviour seems to have improved in 10.2
