Adding Transition to Text in Secondary Storyline
Sascha Engel
on Apr 9, 2015 at 10:42:24 am
I have a weird problem:
When I have a text on the Secondary Storyline as Super over some images on the Primary Storyline,
and I ad a transition to the Text layer, it effects the entire image, also the one on the Primary Storyline.
How come?
Ut's a sudden bug?
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
Jeremy Garchow
Re: Adding Transition to Text in Secondary Storyline
on Apr 9, 2015 at 11:56:59 am
What transition?
Sascha Engel
on Apr 9, 2015 at 12:19:39 pm
Ji Jeremy,
Actually, I tried it with several ones. In this case is was mainly blurs & wooshes.
Greetings,
Sascha Engel
Nick Toth
on Apr 9, 2015 at 12:41:05 pm
Some transitions are only made to work between clips. Some can be modified in Motion to work properly with titlesand some can't. In Motion you have to turn off A or B depending on if you want an incoming or outgoing transition.
anickt
Sascha Engel
on Apr 9, 2015 at 12:49:07 pm
Thanx for the quick reply. Will try that!
Once of the things, where I expected X to behave like 7. ;-)
Sascha Engel
Bret Williams
on Apr 9, 2015 at 1:33:00 pm
When you have 7 layers stacked up and you want to slide or whoosh between them all, you'll appreciate those transitions more.
Sascha Engel
on Apr 9, 2015 at 2:33:30 pm
You are right, for that occasion it rocks, but I'd like to have a choice, and the fact that I cannont make it work stand alone only for the superimposed text layer really sucks.
I ended up doing it in AE, since due to deadline patience was low.
Sascha Engel
Nick Toth
on Apr 9, 2015 at 8:05:51 pm
Try these. They are copies of other transitions modified specifically for text.
8716_texttransitions.zip
anickt
Sascha Engel
on Apr 10, 2015 at 5:39:42 am
Thank you! Very generous of you!
