FCPX will no longer allow me to switch to proxy media
Alex Ricciardi
on Mar 27, 2015 at 6:59:51 pm
Hi all,
For some reason, FCPX suddenly stopped allowing me to switch to proxy media. I go to the drop down in the upper right of the Viewer, select "Proxy" and... nothing happens. If I click the drop down again, Original/Optimized is selected, as if I had never clicked Proxy.
Has anyone run into this issue before?
Thanks for any help you can give.
Alex Ricciardi
Editor, Colorist
Endless Picnic
Noah Kadner
Re: FCPX will no longer allow me to switch to proxy media
on Mar 27, 2015 at 10:36:07 pm
Try resetting preferences.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Alex Ricciardi
on Mar 28, 2015 at 12:22:46 am
Thanks Noah. I should have mentioned that I have so far used Preference Manager to trash preferences, as well as manually trashed preferences, and the problem persists.
I've also discovered that some other problems are occurring as well. Specifically, I can't skim anymore (can't get the "Skimming" checkmark in the dropdown or use the keyboard shortcut), and I can't turn off snapping (through menu or keyboard shortcut).
I've seen a few reports of the skimming issue being fixed by toggling the position tool on and off but that doesn't seem to be doing it in my case. How bizarre!
Any other thoughts would be greatly appreciated.
Alex Ricciardi
Editor, Colorist
Endless Picnic
Noah Kadner
on Mar 28, 2015 at 1:00:35 am
That sounds like a corrupted install. Try deleting and reinstalling FCPX from the Mac App Store. If the problem persists- go through https://support.apple.com/en-us/HT203477
Noah
Call Box Training
