Trying to output video from FCPX to FCP7 to go to DVCAM tape. Having issues with new computer
Steve Marshall
on Mar 22, 2015 at 5:18:18 pm
Hello,
I just upgraded to a new Macpro tower. I transferred all the info from my old mac. I work in FCPX but I have to output to DVCAM Tape for broadcast. I usually output my final movie in FCPX via a compressor setting DV/DVCpro NTSC progressive mpeg-2 video, 720X480 QT movie. Then I put it into FCP7 to output to DVCAM tape.
Now with my new Macpro tower the setting is not there and I can't figure out how to get it. Whenever I try anything in FCPX output the ending result is a squished version when I import to FCP7. Strange thing started to happen lately is in FCP7 the import window disappears so quickly I can't use it any more so I drag the video on the timeline.
The DV/DVpro Ntsc Progressive option is not available anymore in Compressor 4.1.3.
Anyone know how to do that for today and if you know of a better workflow I would love to hear about it.
Thank you,
Steve
John Rofrano
Re: Trying to output video from FCPX to FCP7 to go to DVCAM tape. Having issues with new computer
on Mar 23, 2015 at 3:12:20 pm
[Steve Marshall] "I usually output my final movie in FCPX via a compressor setting DV/DVCpro NTSC progressive mpeg-2 video, 720X480 QT movie. Then I put it into FCP7 to output to DVCAM tape. "
That's a confusing statement. DV/DVCPRO is DV25 format not MPEG-2 format. Also DV is interlaced so I'm not sure why you think you need progressive.
[Steve Marshall] "The DV/DVpro Ntsc Progressive option is not available anymore in Compressor 4.1.3. "
Have you tried creating your own Compressor template? I created one for DV/DVCPRO NTSC and exposed it to FCP X without a problem. You create the template in Compressor 4 but you add it to FCP X from within FCP X using Add Destination....
~jr
http://www.johnrofrano.com
http://www.vasst.com
Steve Marshall
on Mar 23, 2015 at 5:55:48 pm
Hello John,
Originally the option was available in Compressor but now it doesn't seem to be there so I'm unclear how to create one.
Regards,
Steve
John Rofrano
on Mar 24, 2015 at 11:32:23 pm
[Steve Marshall] "Originally the option was available in Compressor but now it doesn't seem to be there so I'm unclear how to create one. "
Hi Steve. It's pretty easy. Here's how:
  1. Open Compressor 4
  2. Select the Current tab (Command ⌘ + 1)
  3. Select the Settings panel (Shift + Command ⌘ + 1)
  4. In the lower left press the plus (+) icon and select New Settings...
  5. Select Format: QuickTime Movie
  6. Make the Name: DV/DVCPRO NTSC
  7. Make the Description: DV/DVCPRO 720x480 NTSC 60i
  8. Press OK
  9. Select the Video Tab
  10. Press the Change... button next to QuickTime Settings
  11. Select DV/DVCPRO NTSC from the Compression Type
  12. Make any other adjustments like 16;9 and high quality
  13. Press OK
  14. That's it! You should now have a new setting in the CUSTOM list called DV/DVCPRO NTSC.
    Now go into FCP X and use File | Share | Add Destination..., double-click on Compressor Settings or drag it to the list on the left:
    Then scroll down to your new DV/DVCPRO NTSC setting, select it and click OK.
    Congratulations... you now have a DV/DVCPRO NTSC destination in FCP X. ;-)
    ~jr
Steve Marshall
on Mar 25, 2015 at 4:07:25 am
John,
This is amazing instructions. Thank you very much. I will give it a try shortly.
Regards,
Steve Marshall
John Rofrano
on Mar 25, 2015 at 11:04:18 am
You're welcome Steve. I should probably make it into a tutorial on my web site so I can refer to it later. ;-) Let us know how you make out.
~jr
Steve Marshall
on Mar 25, 2015 at 4:15:42 pm
It worked like a charm.
Regards,
Steve
John Rofrano
on Mar 26, 2015 at 11:24:21 am
Fantastic! I'm glad I could help.
~jr
Bret Williams
on Mar 23, 2015 at 10:56:04 pm
DV doesn't have to be progressive. We rendered out progressive DV all the time. DV TAPE must be interlaced, but when written to tape in fields you simply got two fields of the same action. PSF I guess.
