Final Cut Pro X project file corrupted - I've tried everything
Tom Wall
on Mar 17, 2015 at 1:23:33 pm
I finished working on a project last night. This morning Final Cut Pro X crashed whilst loading the project. I tried rebooting but it made no difference. I then looked up advice on various blogs and forums. I move the project file to my desktop and FCPX opened fine. But I need to get the project file working as I've spent a long time working on it.
This is what I've tried so far:
1. Moving the backup into the project folder and then loading FCPX. It crashed whilst loading.
2. Opening the backup from the backup folder. It crashed whilst loading.
3. Deleting preferences. It crashed whilst loading
4. Deleting thumbnail and peaks data from the project then loading FCPX. It crashed whilst loading.
I haven't been able to export the file and then load it in a new library as it crashed FCPX as soon as it opens.
Is there anything else I can try? And what can I do to avoid it happening again?
Jeremy Garchow
Re: Final Cut Pro X project file corrupted - I've tried everything
on Mar 17, 2015 at 3:36:46 pm
What version of FCPX?
[Tom Wall] "3. Deleting preferences. It crashed whilst loading"
Did you double click the Library again, or did you try and open FCPX itself after deleting prefs? I would try holding option while FCPX loads. This will bring up a dialogue window. Choose to make a new library. Does FCPX open after that?
IF it does, then try loading the library with FCPX open.
Jeremy
Tom Wall
on Mar 17, 2015 at 4:07:35 pm
I'm using 10 0 4
I opened FCPX rather than the library after deleting the preferences.
When say double click on the library, what do you mean exactly?
Also, what do you mean by the 'holding option'?
Could the problem be that I'm using a Mac Mini (not ideal I know - but I have edited other short videos on it)?
Thanks for your help.
Jeremy Garchow
on Mar 17, 2015 at 4:53:04 pm
10.0.4 or 10.1.4?
Tom Wall
on Mar 17, 2015 at 4:59:12 pm
10 0 4
Jeremy Garchow
on Mar 17, 2015 at 5:08:31 pm
thanks for clarifying. My above advice won't make any sense, so please disregard.
Move that project out of the Final Cut Projects folder and try to launch FCPX. Does it launch?
Tom Wall
on Mar 17, 2015 at 5:17:25 pm
Yes that was one of the first things I tried. It works fine when the project file is on my desktop.
Tom Wall
on Mar 17, 2015 at 5:40:52 pm
I mean FCPX works fine NOT the project.
Jeremy Garchow
on Mar 17, 2015 at 5:58:36 pm
OK. Now that I know that you are on 10.0.4, that makes sense.
If I remember correctly, and it's been a while, you have to rename the backup file to "CurrentVersion" from the dated name.
If that doesn't work, it might be gone. The early days of FCPX were trying times.
Jeremy Garchow
on Mar 17, 2015 at 6:00:36 pm
[Jeremy Garchow] "If I remember correctly, and it's been a while, you have to rename the backup file to "CurrentVersion" from the dated name.
and put in the in the Project name folder (the easiest way to do this is to duplicate it in the backup folder, move the dupe to the project folder, and rename.
Tom Wall
on Mar 17, 2015 at 6:06:29 pm
Yes I tried moving and renaming the backup but that didn't work either.
Even if I can't get it back I'd like to know what caused it so I can avoid it happening again.
Might I be placing too many demands on my Mac Mini?
Thanks.
Jeremy Garchow
on Mar 17, 2015 at 6:08:40 pm
I don't know. Earlier versions of FCPX were simply less reliable.
If you post the original damaged project, I could try and take a look at it for you.
Jeremy
Tom Wall
on Mar 18, 2015 at 8:50:34 am
In case this helps, here is the problem report. FCPX manages to almost load up the entire project before crashing.
Also, I've run Pro Maintenance Tools on the project file and footage. It found no problems.
Process: Final Cut Pro [319]
Path: /Volumes/VOLUME/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCut
Version: 10.0.4 (197051)
Build Info: ProEditor-197050125~3
Code Type: X86-64 (Native)
Parent Process: launchd [171]
Responsible: Final Cut Pro [319]
User ID: 1198930955
Date/Time: 2015-03-18 08:46:37.055 +0000
OS Version: Mac OS X 10.9.5 (13F1066)
Report Version: 11
Anonymous UUID: 7F41A670-593A-F169-FBAD-AE49F4845C01
Crashed Thread: 9 BGTask: MEBackgroundLoadManager Dispatch queue: NSOperationQueue 0x6080002eb180
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
Background exception: 'vector::_M_range_check' --> { (
0 CoreFoundation 0x00007fff8e66825c __exceptionPreprocess + 172
1 libobjc.A.dylib 0x00007fff82f95e75 objc_exception_throw + 43
2 CoreFoundation 0x00007fff8e667e09 -[NSException raise] + 9
3 Flexo 0x0000000100eea3d8 FFApplicationHandleExceptionThatShouldNotBeIgnoredInBlock + 184
4 Flexo 0x00000001007f2c53 -[FFBackgroundTask main] + 355
5 Foundation 0x00007fff82707ec1 -[__NSOperationInternal _start:] + 631
6 Foundation 0x00007fff82707b6b __NSOQSchedule_f + 64
7 libdispatch.dylib 0x00007fff82a0228d _dispatch_client_callout + 8
8 libdispatch.dylib 0x00007fff82a067e3 _dispatch_async_redirect_invoke + 154
9 libdispatch.dylib 0x00007fff82a0228d _dispatch_client_callout + 8
10 libdispatch.dylib 0x00007fff82a04082 _dispatch_root_queue_drain + 326
11 libdispatch.dylib 0x00007fff82a05177 _dispatch_worker_thread2 + 40
12 libsystem_pthread.dylib 0x00007fff8cee0ef8 _pthread_wqthread + 314
13 libsystem_pthread.dylib 0x00007fff8cee3fb9 start_wqthread + 13
abort() called
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff8b499a1a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8b498d18 mach_msg + 64
2 com.apple.CoreFoundation 0x00007fff8e58af15 __CFRunLoopServiceMachPort + 181
3 com.apple.CoreFoundation 0x00007fff8e58a539 __CFRunLoopRun + 1161
4 com.apple.CoreFoundation 0x00007fff8e589e75 CFRunLoopRunSpecific + 309
5 com.apple.HIToolbox 0x00007fff84285a0d RunCurrentEventLoopInMode + 226
6 com.apple.HIToolbox 0x00007fff842857b7 ReceiveNextEventCommon + 479
7 com.apple.HIToolbox 0x00007fff842855bc _BlockUntilNextEventMatchingListInModeWithFilter + 65
8 com.apple.AppKit 0x00007fff8743a24e _DPSNextEvent + 1434
9 com.apple.AppKit 0x00007fff8743989b -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
10 com.apple.AppKit 0x00007fff8742d99c -[NSApplication run] + 553
11 com.apple.prokit 0x0000000100306d3f NSProApplicationMain + 296
12 com.apple.FinalCut 0x0000000100001a68 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8b49e662 kevent64 + 10
1 libdispatch.dylib 0x00007fff82a04421 _dispatch_mgr_invoke + 239
2 libdispatch.dylib 0x00007fff82a04136 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8b49de6a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8cee0f08 _pthread_wqthread + 330
2 libsystem_pthread.dylib 0x00007fff8cee3fb9 start_wqthread + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff8b49d716 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff8cee1c3b _pthread_cond_wait + 727
2 com.apple.progl.framework 0x0000000101ae8131 (anonymous namespace)::threadFunc(void*) + 61
3 com.apple.procore.framework 0x0000000100164f9e PCThread::startup(void*) + 18
4 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
5 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
6 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 4:: com.apple.flexo.throttled-scheduled-io
2 com.apple.Flexo 0x000000010082a898 Synchronizable::Wait() + 56
3 com.apple.Fig.provider 0x000000010578ff88 0x105761000 + 192392
4 com.apple.Flexo 0x00000001008336aa Thread::RunHelper(void*) + 42
5 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
6 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
7 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 5:
Thread 6:
5 com.apple.CoreMediaIO.FCPX.Lion 0x0000000103f8f3ac CMIO::DAL::RunLoop::OwnThread(void*) + 152
6 com.apple.CoreMediaIO.FCPX.Lion 0x0000000103f85de5 CAPThread::Entry(CAPThread*) + 97
7 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
8 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
9 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 7:: CVDisplayLink
1 libsystem_pthread.dylib 0x00007fff8cee1c77 _pthread_cond_wait + 787
2 com.apple.CoreVideo 0x00007fff8630b464 CVDisplayLink::waitUntil(unsigned long long) + 244
3 com.apple.CoreVideo 0x00007fff8630a998 CVDisplayLink::runIOThread() + 496
4 com.apple.CoreVideo 0x00007fff8630a78f startIOThread(void*) + 147
Thread 8:
Thread 9 Crashed:: BGTask: MEBackgroundLoadManager Dispatch queue: NSOperationQueue 0x6080002eb180
0 libsystem_kernel.dylib 0x00007fff8b49d866 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff8cee035c pthread_kill + 92
2 libsystem_c.dylib 0x00007fff901ffb1a abort + 125
3 com.apple.Flexo 0x000000010087d897 FFApplicationHandleExceptionThatShouldNotBeIgnored + 407
4 com.apple.Flexo 0x0000000100eea40a FFApplicationHandleExceptionThatShouldNotBeIgnoredInBlock + 234
5 com.apple.Flexo 0x00000001007f2c53 -[FFBackgroundTask main] + 355
6 com.apple.Foundation 0x00007fff82707ec1 -[__NSOperationInternal _start:] + 631
7 com.apple.Foundation 0x00007fff82707b6b __NSOQSchedule_f + 64
8 libdispatch.dylib 0x00007fff82a0228d _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fff82a067e3 _dispatch_async_redirect_invoke + 154
10 libdispatch.dylib 0x00007fff82a0228d _dispatch_client_callout + 8
11 libdispatch.dylib 0x00007fff82a04082 _dispatch_root_queue_drain + 326
12 libdispatch.dylib 0x00007fff82a05177 _dispatch_worker_thread2 + 40
13 libsystem_pthread.dylib 0x00007fff8cee0ef8 _pthread_wqthread + 314
14 libsystem_pthread.dylib 0x00007fff8cee3fb9 start_wqthread + 13
Thread 10:
Thread 11:: MIO Mounting Thread
2 com.apple.Foundation 0x00007fff82737f50 -[NSCondition waitUntilDate:] + 344
3 com.apple.Foundation 0x00007fff8272edf8 -[NSConditionLock lockWhenCondition:beforeDate:] + 232
4 com.apple.proapps.MIO 0x000000010175200c -[PluginLockPair scanPaths] + 284
5 com.apple.Foundation 0x00007fff82766d8b __NSThread__main__ + 1318
6 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
7 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
8 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 12:: MIO Mounting Thread
Thread 13:: MIO Mounting Thread
Thread 14:: MIO Mounting Thread
Thread 15:: MIO Mounting Thread
Thread 16:: com.apple.dvdplayback-DDPTask
0 libsystem_kernel.dylib 0x00007fff8b499a56 semaphore_wait_trap + 10
1 com.apple.AVCHDPlugin 0x0000000120a7a007 semaphore_wait(viona_semaphore_t*) + 55
2 com.apple.AVCHDPlugin 0x0000000120a87680 WinPortServer::ProcessMessages() + 768
3 com.apple.AVCHDPlugin 0x0000000120a0bae3 DDP_Init + 707
4 com.apple.AVCHDPlugin 0x0000000120a79810 ST20Thread::Run(PThreadRunParams*) + 32
Thread 17:: com.apple.flexo.player-render (playback)
4 com.apple.Flexo 0x00000001006cdfe5 -[FFPlayer _waitForAttention] + 37
5 com.apple.Flexo 0x00000001006d41f4 -[FFPlayer playerRenderThreadMain:] + 324
6 com.apple.Foundation 0x00007fff82766d8b __NSThread__main__ + 1318
Thread 18:: com.apple.flexo.time-rate-change-controller
2 com.apple.Flexo 0x00000001006dbdeb TimeRateChangeController::threadFunction() + 299
3 com.apple.Flexo 0x00000001006ece7d TimeRateChangeController::thread_routine(void*) + 61
Thread 19:: com.apple.flexo.worker-thread
1 com.apple.Flexo 0x000000010089bae0 WorkerThread::Run() + 224
2 com.apple.Flexo 0x00000001008336aa Thread::RunHelper(void*) + 42
3 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
4 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
5 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 20:: CVDisplayLink
Thread 21:: com.apple.coremedia.scheduledfileio
2 com.apple.CoreMedia.ProAppsSupport 0x000000010029cc11 WaitOnCondition + 14
3 com.apple.CoreMedia.ProAppsSupport 0x000000010029cddd FigSemaphoreWaitRelative + 167
4 com.apple.CoreMedia.ProAppsSupport 0x000000010029aeea FigScheduledFileIOThread + 5109
5 com.apple.CoreMedia.ProAppsSupport 0x000000010029dcea figThreadMain + 397
Thread 22:: com.apple.helium-render-queue-exec-unit-cpu
2 com.apple.Helium.HeliumRender 0x0000000102e8dc6e HGSynchronizable::Wait() + 46
3 com.apple.Helium.HeliumRender 0x0000000102da7b8f HGRenderQueue::GetRenderJob(HGRenderExecUnit*, HGRenderJob**) + 207
4 com.apple.Helium.HeliumRender 0x0000000102d9f35e HGRenderExecUnit::RunLoop() + 110
5 com.apple.Helium.HeliumRender 0x0000000102d9f2e4 StartRenderExecUnitFunc(void*) + 20
Thread 23:: com.apple.helium-render-queue-exec-unit-cpu
Thread 24:: com.apple.coremedia.JVTlib
1 com.apple.VideoToolbox.ProAppsSupport 0x0000000101eec12b VTImageRotationSessionCreate + 77645
2 com.apple.VideoToolbox.ProAppsSupport 0x0000000101eebad8 VTImageRotationSessionCreate + 76026
Thread 25:: com.apple.coremedia.JVTlib
2 com.apple.VideoToolbox.ProAppsSupport 0x0000000101fa93f0 JVTLibDecoDispose + 479632
Thread 26:: Dispatch queue: NSOperationQueue 0x608003a2d9e0
0 libsystem_kernel.dylib 0x00007fff8b49e962 pread + 10
1 com.apple.ImageIO.framework 0x00007fff89e15146 _CFDataCreateWithMappedFile + 334
2 com.apple.ImageIO.framework 0x00007fff89e14ee3 CGImageReadCreateWithFile + 204
3 com.apple.ImageIO.framework 0x00007fff89e14c59 CGImageSourceCreateWithURL + 592
4 com.apple.imageKit 0x00007fff8cc0f4d0 -[IKImageWrapper _size] + 453
5 com.apple.imageKit 0x00007fff8cc0fa6c -[IKImageWrapper size] + 70
6 com.apple.imageKit 0x00007fff8cd03811 -[IKThumbnailBuilder computeThumbnail] + 67
7 com.apple.imageKit 0x00007fff8cd04e12 -[IKThumbnailOperation main] + 33
8 com.apple.Foundation 0x00007fff82707ec1 -[__NSOperationInternal _start:] + 631
9 com.apple.Foundation 0x00007fff82707b6b __NSOQSchedule_f + 64
11 libdispatch.dylib 0x00007fff82a067e3 _dispatch_async_redirect_invoke + 154
12 libdispatch.dylib 0x00007fff82a0228d _dispatch_client_callout + 8
13 libdispatch.dylib 0x00007fff82a04082 _dispatch_root_queue_drain + 326
14 libdispatch.dylib 0x00007fff82a05177 _dispatch_worker_thread2 + 40
15 libsystem_pthread.dylib 0x00007fff8cee0ef8 _pthread_wqthread + 314
16 libsystem_pthread.dylib 0x00007fff8cee3fb9 start_wqthread + 13
Thread 27:: com.apple.helium-unit
0 libsystem_kernel.dylib 0x00007fff8b49d746 __psynch_mutexwait + 10
1 libsystem_pthread.dylib 0x00007fff8cee2779 _pthread_mutex_lock + 372
2 com.apple.Helium.HeliumRender 0x0000000102e434d2 hg_pthread_loop(void*) + 98
Thread 28:: com.apple.helium-unit
Thread 29:: Dispatch queue: NSOperationQueue 0x608003a2d9e0
Thread 30:
5 com.apple.CoreFoundation 0x00007fff8e63f811 CFRunLoopRun + 97
6 com.apple.qmaster.do 0x000000011ddc90b1 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 187
7 com.apple.AECore 0x00000001089bdeff aecore::CThread::runThread() + 35
8 com.apple.AECore 0x00000001089bbed0 threadProc(void*) + 9
9 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
10 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
11 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 31:: com.apple.helium-texture-finish
2 com.apple.Helium.HeliumRender 0x0000000102e29377 textureFinishThread(void*) + 183
Thread 32:: com.apple.helium-render-queue-exec-unit-gpu
Thread 33:: com.apple.helium-render-queue-pbo-readback-unit
3 com.apple.Helium.HeliumRender 0x0000000102da94c0 HGRenderQueue::GetPBOReadbackJob(HGPBOReadbackExecUnit*, HGPBOReadbackJob**) + 80
4 com.apple.Helium.HeliumRender 0x0000000102d9e075 StartPBOExecUnitFunc(void*) + 85
Thread 34:: com.apple.helium-render-queue-pbo-readback-unit
Thread 35:: com.apple.helium-render-queue-exec-unit-gpu
Thread 36:: com.apple.helium-render-queue-pbo-readback-unit
Thread 37:: com.apple.helium-render-queue-pbo-readback-unit
Thread 38:
5 com.apple.AppKit 0x00007fff875da05e _NSEventThread + 144
Thread 39:: com.apple.appkit-heartbeat
0 libsystem_kernel.dylib 0x00007fff8b49da3a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff9021edc0 nanosleep + 200
2 libsystem_c.dylib 0x00007fff9021ecb2 usleep + 54
3 com.apple.AppKit 0x00007fff8769e17d -[NSUIHeartBeat _heartBeatThread:] + 2132
4 com.apple.Foundation 0x00007fff82766d8b __NSThread__main__ + 1318
Thread 40:: com.apple.CoreAnimation.CAOpenGLLayer
6 com.apple.QuartzCore 0x00007fff8dfe7922 CAOpenGLLayer_render_thread(void*) + 162
7 com.apple.QuartzCore 0x00007fff8deb42ad thread_fun + 25
8 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
9 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
10 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 41:
0 libsystem_kernel.dylib 0x00007fff8b49d9aa __select + 10
1 com.apple.AECore 0x00000001089bdf2c aecore::CThread::runThread() + 80
2 com.apple.AECore 0x00000001089bbed0 threadProc(void*) + 9
Thread 42:: com.apple.CFSocket.private
1 com.apple.CoreFoundation 0x00007fff8e5d6a03 __CFSocketManager + 867
2 libsystem_pthread.dylib 0x00007fff8cedf899 _pthread_body + 138
3 libsystem_pthread.dylib 0x00007fff8cedf72a _pthread_start + 137
4 libsystem_pthread.dylib 0x00007fff8cee3fc9 thread_start + 13
Thread 43:: com.apple.flexo.player-render (playback)
Thread 44:: com.apple.flexo.time-rate-change-controller
Thread 45:: com.apple.flexo.worker-thread
Thread 46:: com.apple.coremedia.JVTlib
Thread 47:: com.apple.coremedia.JVTlib
Thread 48:
2 com.apple.Foundation 0x00007fff827b0912 +[NSThread sleepUntilDate:] + 176
3 com.apple.imageKit 0x00007fff8cc330da -[IKImageBrowserView(ImageBrowserImport) _prefetchThumbnails:state:] + 542
4 com.apple.imageKit 0x00007fff8cc33871 -[IKImageBrowserView(ImageBrowserImport) startScrollPrefetchTask] + 718
5 com.apple.imageKit 0x00007fff8ccd54fb -[IKTaskManager taskLoop] + 2193
Thread 49:: com.apple.coremedia.JVTlib
Thread 50:: com.apple.coremedia.JVTlib
Thread 51:
Thread 52:
Thread 9 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x000000011e583000 rcx: 0x000000011e582a98 rdx: 0x0000000000000000
rdi: 0x0000000000011d47 rsi: 0x0000000000000006 rbp: 0x000000011e582ac0 rsp: 0x000000011e582a98
r8: 0x00007fff882ed2ec r9: 0x0000000000000000 r10: 0x000000000c000000 r11: 0x0000000000000206
r12: 0x00000001012b64e8 r13: 0x00007fff725cdf38 r14: 0x0000000000000006 r15: 0x0000600001461540
rip: 0x00007fff8b49d866 rfl: 0x0000000000000206 cr2: 0x000000011a87a000
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x100000000 - 0x1000caff7 com.apple.FinalCut (10.0.4 - 197051) <17BE6450-60D1-5D52-44B8-78E9678D26AF> /Volumes/VOLUME/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0x100146000 - 0x100225fef com.apple.procore.framework (4.0.2 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProCore.framework/Versions/A/ProCore
0x10027f000 - 0x1002c7ff7 com.apple.CoreMedia.ProAppsSupport (1.0 - 705.73) <06403DF9-88E6-91FA-836E-B5305AC1842E> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x1002e9000 - 0x1004fbfff com.apple.prokit (7.4.0 - 1957) <3EF7F2B2-5539-3004-9A34-8741371FBD4D> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0x10068f000 - 0x10128bff7 com.apple.Flexo (1.0.0 - 19703.3.25) <6A284C36-194D-BB87-D296-D3E9F8C0B103> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Flexo
0x101720000 - 0x1017ecfef com.apple.proapps.MIO (2.0 - 19703.3.25) <6F2D33F9-0079-9EF5-80E4-CFD8131838BB> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x101853000 - 0x101872fff com.apple.pro.sharedstudio (1.0 - 19703.3.25) <93F08F35-379F-9D21-C5F2-D81902BFE278> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/StudioSharedResources.framework/Versions/A/StudioSharedResources
0x101893000 - 0x101960fef com.apple.TLKit (1.0 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/TLKit.framework/Versions/A/TLKit
0x1019c1000 - 0x101a65fef com.apple.LunaKit (1.0 - 19703.3.25) <7B3231B7-35D8-E077-83BA-E1985F740024> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/LunaKit.framework/Versions/A/LunaKit
0x101add000 - 0x101b1afff com.apple.progl.framework (1.0 - 19703.3.25) <2E2005F0-DA39-AA4A-3306-2B1C77C17D08> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProGL.framework/Versions/A/ProGL
0x101b5d000 - 0x101c0cfef com.apple.ProAppsFxSupport (4.0.0 - 19703.3.25) <03ED0841-C538-9971-004E-887175FE6128> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProAppsFxSupport.framework/Versions/A/ProAppsFxSupport
0x101e35000 - 0x101e53fef com.apple.DeepSkyLite (0.6 - 19703.3.25) <5819C636-A7A5-5BF9-9DD5-86ACDCFB9F66> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/DeepSkyLite.framework/Versions/A/DeepSkyLite
0x101e68000 - 0x102275fff com.apple.VideoToolbox.ProAppsSupport (1.0 - 705.73) <65ABE155-6852-F6C5-9AA4-6BA04E43EE4E> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x1022ff000 - 0x1026bbff7 com.apple.MediaToolbox.ProAppsSupport (1.0 - 705.73) <04A8D97F-0B45-8F54-CA9C-781520BA84DF> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x10272d000 - 0x10286bfef com.apple.prochannel.framework (4.0.2 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProChannel.framework/Versions/A/ProChannel
0x10291e000 - 0x10291efff com.apple.Helium (3.1.0 - 19703.3.25) <226B96AC-CC2D-6062-78AF-F5F0423AE670> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Helium
0x102922000 - 0x10299dfff com.apple.proinspector.framework (4.0.2 - 19703.3.25) <9A8798F5-51E2-2F46-E669-A5319DCED691> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProInspector.framework/Versions/A/ProInspector
0x1029e4000 - 0x102a0bff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <72C03A08-5C3C-3D7F-87CD-797B661F99CF> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x102a27000 - 0x102a3cfef com.apple.MAAudioUnitSupport (1.0.0 - 101) <6EBF5571-0CBE-4EEC-1C33-A9C798DD919E> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/MAAudioUnitSupport.framework/Versions/A/MAAudioUnitSupport
0x102a4c000 - 0x102a9bfff com.apple.proshapes.framework (1.0 - 19703.3.25) <2F6DA227-B865-25E9-5BD4-490CCF4E4F72> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProShapes.framework/Versions/A/ProShapes
0x102ac7000 - 0x102bd9fff com.apple.proosc.framework (3.1.0 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProOSC.framework/Versions/A/ProOSC
0x102c3f000 - 0x102c59ff7 com.apple.iLifeFaceRecognition (1.0 - 21) <5D45F816-8F9C-C6F5-4050-1331BCA3ADB2> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/iLifeFaceRecognition.framework/Versions/A/iLifeFaceRecognition
0x102c6c000 - 0x102ce9fff com.apple.procurveeditor.framework (3.1.0 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProCurveEditor.framework/Versions/A/ProCurveEditor
0x102d24000 - 0x102d36fef com.apple.TLKEventDispatcher (1.0 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/TLKEventDispatcher.framework/Versions/A/TLKEventDispatcher
0x102d44000 - 0x1030f2fe7 com.apple.Helium.HeliumRender (2.1.0 - 19703.3.25) <0D06A095-BB06-D193-2FA1-4E90A72F8FC2> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0x103216000 - 0x1032e1fef com.apple.Helium.Heliumfilters (2.1.0 - 19703.3.25) <6D806578-FFC4-A63D-A650-7427E2A058D4> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumFilters.framework/Versions/A/HeliumFilters
0x103597000 - 0x10384bfef com.apple.Helium.HeliumSensoCore (2.0.2 - 19703.3.25) <96791AF1-948E-C893-7B94-AA0CF6F82AE4> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumSensoCore.framework/Versions/A/HeliumSensoCore
0x1038c1000 - 0x1038ecfff com.apple.FWAVC (403.47 - 47) <20BAF98C-349A-38E1-ACE1-C0838546D248> /System/Library/PrivateFrameworks/FWAVC.framework/Versions/A/FWAVC
0x103903000 - 0x103905fff +eOkaoCom.dylib (1) <393F340C-3AD1-C89B-6C37-9D8ABF4BFFD9> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/iLifeFaceRecognition.framework/Versions/A/Resources/eOkaoCom.dylib
0x103909000 - 0x103930ff2 +eOkaoPt.dylib (1) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/iLifeFaceRecognition.framework/Versions/A/Resources/eOkaoPt.dylib
0x103937000 - 0x10396cfe7 +eOkaoDt.dylib (1) <7A74253D-8930-6FF1-B513-0929C4E111A2> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/iLifeFaceRecognition.framework/Versions/A/Resources/eOkaoDt.dylib
0x103973000 - 0x103adbfef +eOkaoFr.dylib (1) <510E837E-135A-92C8-9AC0-465691EA43D2> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/Frameworks/iLifeFaceRecognition.framework/Versions/A/Resources/eOkaoFr.dylib
0x103ae1000 - 0x103b01fff com.apple.fxplugframework (2.2 - 19703.3.25) <594C318D-269C-6A35-6463-A96F0E64BF7E> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/FxPlug.framework/Versions/A/FxPlug
0x103b17000 - 0x103b26fff com.apple.PluginManager (1.7.4 - 19703.3.25) <7D5E14FF-4A6F-C881-57CE-46E7653BADB8> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/PluginManager.framework/Versions/B/PluginManager
0x103dab000 - 0x103db6fff libGPUSupport.dylib (9.6.1) <23B64473-59E7-3AC2-B8C0-CFCFDDF3F8A3> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x103f00000 - 0x103f03ff7 com.apple.iLMBLogicPlugin (2.8.3 - 390.6) /Library/Application Support/iLifeMediaBrowser/*/iLMBLogicPlugin
0x103f08000 - 0x103f09fff com.apple.iLMBMoviesFolderPlugin (2.8.3 - 390.6) /Library/Application Support/iLifeMediaBrowser/*/iLMBMoviesFolderPlugin
0x103f0e000 - 0x103f10fff com.apple.iLMBPhotoBooth2Plugin (2.8.3 - 390.6) <8EC1CEFB-5E49-3942-A60A-366F9B5BEBBF> /Library/Application Support/iLifeMediaBrowser/*/iLMBPhotoBooth2Plugin
0x103f15000 - 0x103f16fff com.apple.iLMBPhotoBoothPlugin (2.8.3 - 390.6) /Library/Application Support/iLifeMediaBrowser/*/iLMBPhotoBoothPlugin
0x103f83000 - 0x103fd2ff7 com.apple.CoreMediaIO.FCPX.Lion (212.0 - 3191) <6741CF10-3CEA-2D94-16C6-691C8456BDDD> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/CoreMediaLion/CoreMediaIO.framework/Versions/Current/CoreMediaIO
0x105283000 - 0x105286ffa libCGXType.A.dylib (599.35.6) <7DAB1A62-D475-37F1-8234-07649906E234> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x105646000 - 0x10564bff7 com.apple.URLMount.CIFSPlugin (6.0.1 - 6.0.1) <831D5DAD-1448-3A84-961D-11D28E859AD9> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
0x10565a000 - 0x105672ffb com.apple.SMBClient (2.0.1 - 2.0.1) <620AB6BB-8518-3456-90A5-FD9ED2621907> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
0x10567d000 - 0x1056ebffb com.apple.DCERPC (2.0 - 58) <616D8D13-2FD5-33B0-98E5-67ABE3442B22> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
0x105751000 - 0x10575afef com.apple.Audio.provider (1.0.0 - 19703.3.25) <2941DD1D-774F-0BB1-B8C7-13CFB7230292> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/MediaProviders/AudioProvider.fxp/Contents/MacOS/AudioProvider
0x105761000 - 0x1057abfe7 com.apple.Fig.provider (1.0.0 - 19703.3.25) <028EEE74-4E3D-1BDD-8562-BF6416E5E4E5> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/MediaProviders/FigProvider.fxp/Contents/MacOS/FigProvider
0x1057c1000 - 0x1057f0fff com.apple.proapps.AppleAVCIntraCodec (1.0.1 - 5708) <86B1E465-5CD9-407E-CEF0-EED1C8031F27> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleAVCIntraCodec.bundle/Contents/MacOS/AppleAVCIntraCodec
0x106000000 - 0x10674aff7 libclh.dylib (4.0.3 - 4.0.3) /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
0x1067ee000 - 0x1067f2fe7 com.apple.proapps.AppleCMQTAdapterCodec (1.0 - 1) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/PlugIns/AppleCMQTAdapterCodec.bundle/Contents/MacOS/AppleCMQTAdapterCodec
0x1086f6000 - 0x108746fe7 com.apple.proapps.AppleDVCPROHDCodec (1.0.1 - 5708) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleDVCPROHDCodec.bundle/Contents/MacOS/AppleDVCPROHDCodec
0x10875d000 - 0x10877bfff com.apple.proapps.AppleIMXCodec (1.0.1 - 5708) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleIMXCodec.bundle/Contents/MacOS/AppleIMXCodec
0x10878d000 - 0x1087bdfef com.apple.proapps.AppleIntermediateCodec (1.0.1 - 5718) <681C1BAC-DD5A-B885-FD51-16A211D98E9D> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleIntermediateCodec.bundle/Contents/MacOS/AppleIntermediateCodec
0x1087d3000 - 0x108898fff com.apple.proapps.AppleMPEG2Codec (1.0.2 - 5708) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleMPEG2Codec.bundle/Contents/MacOS/AppleMPEG2Codec
0x1088b5000 - 0x10894bfef com.apple.proapps.AppleProResCodec (1.0.3 - 5758.29) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleProResCodec.bundle/Contents/MacOS/AppleProResCodec
0x108989000 - 0x108998ff7 com.apple.proapps.AppleUncompressedCodec (1.0.1 - 5708) <902E7643-1858-5A57-7A93-BFE41B65CA37> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/PlugIns/Codecs/AppleUncompressedCodec.bundle/Contents/MacOS/AppleUncompressedCodec
0x1089a1000 - 0x108b0dfef com.apple.AECore (4.0.3 - 303) <8A25EA37-E0C1-144D-01F4-E8D6EBCC5F51> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/AECore.framework/Versions/A/AECore
0x108b8f000 - 0x108ba9ff7 com.apple.framework.Admin (13.0 - 13.0) <4C6F3194-B65B-34EC-A825-081FC74B6D16> /System/Library/PrivateFrameworks/Admin.framework/Versions/A/Admin
0x108bc3000 - 0x108be3ff7 com.apple.FxPlug.provider (1.0.0 - 19703.3.25) <0F477F94-71E5-8561-0F18-BFFEC62E694A> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/MediaProviders/FxPlugProvider.fxp/Contents/MacOS/FxPlugProvider
0x108bf0000 - 0x108e42ff7 com.apple.Motion.effect (5.0.0 - 19704.8.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/MediaProviders/MotionEffect.fxp/Contents/MacOS/MotionEffect
0x108e77000 - 0x109037ff7 com.apple.Lithium (5.0.0 - 19704.8.25) <0648F4A5-F5F7-EDCF-594E-848857174794> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Lithium.framework/Versions/A/Lithium
0x1090ca000 - 0x109d0efef Ozone (19704.8.25) <1E598732-348F-601A-8AA7-1DFD7CF2B07A> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Ozone.framework/Versions/A/Ozone
0x10a0fe000 - 0x10a157ff7 com.apple.ProGraphics (5.0.0 - 19704.8.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProGraphics.framework/Versions/A/ProGraphics
0x10a184000 - 0x10a19eff7 com.apple.promath.framework (5.0.0 - 19704.8.25) <9985B873-AA33-7E56-C9A7-801CA219369F> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProMath.framework/Versions/A/ProMath
0x10a1a7000 - 0x10a87fff7 com.apple.motion.TextFramework (5.0.0 - 19704.8.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/TextFramework.framework/Versions/A/TextFramework
0x10a975000 - 0x10aa3cfe7 com.apple.ProMedia (5.0.0 - 19704.8.25) <21C06D40-C36F-72D9-49D6-15496BD2595E> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/ProMedia.framework/Versions/A/ProMedia
0x10aab2000 - 0x10ab8dff7 org.python.python (2.6.8 - 2.6.8) <1A91D8F4-BF9E-36A6-85C4-A00166DD6268> /System/Library/Frameworks/Python.framework/Versions/2.6/Python
0x10abee000 - 0x10ac29ff2 com.apple.audio.midi.CoreMIDI (1.10 - 88) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10ac51000 - 0x10ac63ff7 com.apple.RetimingMath (5.0.0 - 19704.8.25) <4E54A4E2-18E6-0281-47AF-82C0D06542BA> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/RetimingMath.framework/Versions/A/RetimingMath
0x10ac76000 - 0x10acdffff com.apple.proapps.AudioMixEngine (2.0 - 68) <58BA4846-87F7-A80D-4A02-D083100EFA94> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Ozone.framework/Versions/A/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x10b088000 - 0x10b08fff7 com.apple.filter.PAECIAdaptor (1.0 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/FxPlug/PAECIAdaptor.fxplug/Contents/MacOS/PAECIAdaptor
0x10b314000 - 0x10b31cff3 libCGCMS.A.dylib (599.35.6) <09F33B9F-098A-340A-8717-E3BA6849470E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x10b55d000 - 0x10b560fff libspindump.dylib (161.2) /usr/lib/libspindump.dylib
0x10b662000 - 0x10b664ff7 com.apple.music.apps.common.resources (9.1.0 - 279.8) <67622011-AE23-6AE4-0FEB-F7CD38C99460> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/common.res/Contents/MacOS/common
0x1121cc000 - 0x1121effff com.apple.prokit.LionPanels (7.4.0 - 1957) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/LionPanels.bundle/Contents/MacOS/LionPanels
0x112223000 - 0x112225ff7 com.apple.music.apps.efx.resources (9.1.0 - 279.8) <059005E1-FC82-0687-0B93-B65D4601CDBB> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/efx.res/Contents/MacOS/efx
0x113f83000 - 0x113fabffb libRIP.A.dylib (599.35.6) <45A8594F-906E-3EAE-87D4-BA1DB091C690> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x116bb4000 - 0x116bcfff7 com.apple.EDEL (2.5 - 536) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/MacOS/EDEL
0x116be3000 - 0x116c72ff7 com.apple.music.apps.MACore (9.1.0 - 475.15) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Frameworks/MACore.framework/Versions/A/MACore
0x116d5b000 - 0x1170a4fe7 com.apple.music.apps.MADSP (9.1.0 - 586.17) <0C23D10E-CBEC-FA04-D02C-2F2D8AD9B8AF> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Frameworks/MADSP.framework/Versions/A/MADSP
0x11746a000 - 0x117521fef com.apple.music.apps.MAFiles (9.1.0 - 143.14) <93BAA38B-9E11-658C-BA79-7B60806259F3> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Frameworks/MAFiles.framework/Versions/A/MAFiles
0x11756d000 - 0x1175b7fef com.apple.music.apps.MAHarmony (9.1.0 - 198.11) <37FB1C22-4A16-12D5-B978-BCA4C727242C> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Frameworks/MAHarmony.framework/Versions/A/MAHarmony
0x1175d7000 - 0x117a11fef com.apple.music.apps.MAPlugInGUI (9.1.0 - 423.13) <43D20A0B-DE24-8281-5BCF-E0DC6C3A8F2B> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Frameworks/MAPlugInGUI.framework/Versions/A/MAPlugInGUI
0x1185a1000 - 0x1185a3ff7 com.apple.music.apps.egt.resources (9.1.0 - 279.8) <7EC6FF3C-56ED-D700-8283-60256B19E040> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/egt.res/Contents/MacOS/egt
0x1185a8000 - 0x1185aaff7 com.apple.music.apps.evb3.resources (9.1.0 - 279.8) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/evb3.res/Contents/MacOS/evb3
0x1185af000 - 0x1185b1ff7 com.apple.music.apps.evd6.resources (9.1.0 - 279.8) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/evd6.res/Contents/MacOS/evd6
0x1185b6000 - 0x1185b8ff7 com.apple.music.apps.evoc.resources (9.1.0 - 279.8) <4820A0BC-48C8-2D4D-6659-8194FB28FE7F> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/evoc.res/Contents/MacOS/evoc
0x1185bd000 - 0x1185bfff7 com.apple.music.apps.evp88.resources (9.1.0 - 279.8) <7BFB2040-677D-7D82-A29D-223563ECC9E9> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/evp88.res/Contents/MacOS/evp88
0x1185c4000 - 0x1185c6ff7 com.apple.music.apps.mutapdel.resources (9.1.0 - 279.8) <5389AB40-9014-7B05-998E-A275175AAD1F> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/mutapdel.res/Contents/MacOS/mutapdel
0x1185cb000 - 0x1185cdff7 com.apple.music.apps.sphere.resources (9.1.0 - 279.8) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/EDEL.bundle/Contents/Resources/sphere.res/Contents/MacOS/sphere
0x118b00000 - 0x118ba3ff7 ColorSyncDeprecated.dylib (426) <1EBD0729-A174-3EA5-B226-DE63C2E89D14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x118bef000 - 0x118bf3ffd com.apple.audio.AppleHDAHALPlugIn (2.6.3 - 2.6.3f4) <2EB88B27-FA19-3C0C-AA06-7FB8BC56694E> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1195f2000 - 0x1195f2ff7 com.apple.qmaster.swamp (4.0.3 - 4.0.3) <76E9C862-82DE-1F0D-9202-A5168242143C> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x1195f6000 - 0x1195fafff com.apple.Helium.HCache (2.1.0 - 19703.3.25) <32C04DFB-6277-A58C-247F-561D486C527D> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
0x11a826000 - 0x11a826ff7 com.apple.iLMBAppDefPlugin (2.8.3 - 390.6) /Library/Application Support/iLifeMediaBrowser/*/iLMBAppDefPlugin
0x11a9ea000 - 0x11a9eefff com.apple.agl (3.2.3 - AGL-3.2.3) <9851E4CC-DA6B-3AF4-9B06-61BAC289572D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x11b35c000 - 0x11b532ff7 com.apple.motion.Behaviors (5.0.0 - 19704.8.25) <3C93F9D0-E303-82E8-622B-0DE9623EFA4A> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Ozone.framework/Versions/A/PlugIns/Behaviors.ozp/Contents/MacOS/Behaviors
0x11b5ee000 - 0x11b642fff com.apple.Bloodhound (5.0.0 - 19704.8.25) <0CDA199C-1639-1D81-AFFD-E03CC29CC2D4> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Bloodhound.framework/Versions/A/Bloodhound
0x11b7af000 - 0x11b7e5fef com.apple.proapps.flexo.AudioEffects (1.0.0 - 19703.3.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Flexo.framework/Versions/A/PlugIns/Audio/AudioEffects.component/Contents/MacOS/AudioEffects
0x11cab7000 - 0x11cabefff com.apple.ArchiveRADPlug (1.0 - 1008.8) <6ABE6930-BD9A-B627-0750-917E7588A183> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/RADPlugins/Archive.RADPlug/Contents/MacOS/Archive
0x11ce4c000 - 0x11d0ecff7 com.apple.motion.Particles (5.0.0 - 19704.8.25) <444B91C9-6A85-2478-9728-68EEC235421E> /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Ozone.framework/Versions/A/PlugIns/Particles.ozp/Contents/MacOS/Particles
0x11d282000 - 0x11d299ff7 com.apple.motion.Text (5.0.0 - 19704.8.25) /Volumes/VOLUME/Final Cut Pro.app/Contents/Frameworks/Ozone.framework/Versions/A/PlugIns/Text.ozp/Contents/MacOS/Text
0x11d2f9000 - 0x11d2faff7 com.apple.iLMBFolderPlugin (2.8.3 - 390.6) /Library/Application Support/iLifeMediaBrowser/*/iLMBFolderPlugin
0x11d4f0000 - 0x11d4f7fff com.apple.compressor.FilterUI (4.0.3 - 4.0.3) <87765221-ADCA-A789-DB4F-6C5ECA9C62A8> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x11d820000 - 0x11d8bafff com.apple.CompressorKitMAS (4.0.3 - 4.0.3) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
0x11d921000 - 0x11d9f7ff7 com.apple.compressor.StompUI (4.0.3 - 4.0.3) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x11da65000 - 0x11db37ff7 com.apple.compressor.StompTypes (4.0.3 - 19705.1.25) <5F0BFEE2-2D08-9256-9362-E9F51AEE7D7F> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x11dba5000 - 0x11dbaeff7 com.apple.compressor.MediaServerAPI (4.0.3 - 4.0.3) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
0x11dbb8000 - 0x11dbc4fff com.apple.compressor.StompUtil (4.0.3 - 4.0.3) /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x11dbd2000 - 0x11dbdeff7 com.apple.dsppublishing (1.0.1 - 119) <023145C4-9AD1-8ACA-0D77-E117185A56B3> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
0x11dbf3000 - 0x11dc40fff com.apple.qmaster.SwampCore (4.0.3 - 303) <876C0234-B005-A187-094C-E45EEB375A4C> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x11dc6d000 - 0x11dc7cff7 com.apple.qmaster.SwampUtil (4.0.3 - 4.0.3) <1AAEC04B-2E3C-AF94-7456-6373655B1AF6> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x11dc88000 - 0x11dd59fff com.apple.qmaster.SwampTypes (4.0.3 - 4.0.3) <99545098-A88A-4016-DA86-6BD5BCE681AA> /Volumes/VOLUME/Final Cut Pro.app/Contents/PlugIns/Compressor/CompressorKit.bundle/Contents/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/Swamp
Jeremy Garchow
on Mar 18, 2015 at 1:40:53 pm
Do you have any third party plugins or templates installed?
Tom Wall
on Mar 18, 2015 at 2:04:07 pm
No.
Jeremy Garchow
on Mar 18, 2015 at 5:53:46 pm
Digital Rebellion has a tool to try and fix this problem, but there's no guarantee. Might be worth running Crash Analyzer and Project Repair:
http://www.digitalrebellion.com/promaintenance/
Jeremy
Michael Sanders
on Mar 19, 2015 at 11:36:16 pm
Try this..
https://forums.creativecow.net/readpost/344/29439
Michael Sanders
London Based DP/Editor
Tom Wall
on Mar 20, 2015 at 2:04:13 pm
Digital Rebellion's crash analyser and project repair did not help. Looks like there is nothing more than I can try.
Russ Haskell
on Mar 22, 2015 at 1:43:25 pm
I needed to refresh my memory on how this worked in the 10.0.x versions. Looking back at some archived projects, there is a timestamped file in the Backups folder. That file should be renamed CurrentVersion.fcpproject and then used to replace the corrupted CurrentVersion file. Just to be clear, the renamed file needs to be moved up a level for the app to recognize it. (This is just saying what Jeremy said in more words, but I recall having to do this on numerous occasions with success – so it's worth double-checking to see that you followed those steps.)
If you did all that and it still didn't work, your last recourse would be to restore from a system backup.
Russ
