Match Frame to reach to original footage
hisayo kushida
on Mar 10, 2015 at 6:54:08 pm
Hi
I created a library dedicated only to my sequences (projects) separated from the 2 media libraries.
While I'm editing, I try to match frame (Shift-F) to see the original footage or to access footage shot on the same day, and it goes to alias copied to the sequence library instead of
original footage in the media library.
Is there any work around to reach to the original footage in media library?
It's such a pain to manually finding the footage in media library.
Does everyone keep everything in one library even if the footage is huge amount?
Thank you in advance.
Noah Kadner
Re: Match Frame to reach to original footage
on Mar 10, 2015 at 7:22:03 pm
A single Library is designed to hold everything from one project. So you'd be better off placing your projects into a specific Event or Smart Collection within the Master Library instead of slicing it up like that. There's not a way to cross-reference Libraries otherwise.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
hisayo kushida
on Mar 11, 2015 at 12:06:23 am
Noah,
Thank you for your insight.
I will consolidate then.
I just thought it might be less heavy but I guess compiling them into one library make things simple...
Thank you.
Hisayo
