Copy from one Project and paste into a secondary storyline of another
Scott Witthaus
on Feb 23, 2015 at 5:48:34 pm
Ok, there has got to be a "vulcan grip" key combo to do this? As stated in thread title, I want to take a series of still images from one project timeline and paste into a secondary storyline of another. Ideas? Thanks in advance and apologies if this is really simple. Been a long couple of days....
Scott
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
Brett Sherman
Re: Copy from one Project and paste into a secondary storyline of another
on Feb 23, 2015 at 6:21:41 pm
Cmd - Option - Up in the still image timeline to move them out of the primary into a secondary. Select the secondary timeline. Hit Command-C to copy, then paste into your main timeline. Cmd - Opt - Down in the still image timeline to move the clips back into the primary.
Nick Toth
on Feb 23, 2015 at 6:34:33 pm
Select the still images. "Option G" to make them a compound clip. Go to the second sequence. Choose the compound clip in the event browser and use "q" to make an attached compound clip. "Command G" makes it a secondary storyline and then "Shift Command G" to break apart the compound clip. Takes longer to type out than to do it.
anickt
Scott Witthaus
on Feb 23, 2015 at 11:20:31 pm
Two great suggestions. I should have totally thought of the Compound Clip thing! Thanks all.
Scott
Scott Witthaus
1708 Inc./Editorial
Nick Toth
on Feb 24, 2015 at 1:31:03 pm
It never really occurred to me to use compound clips as a way to move large chunks of content around like this until I had been using FCP X for a while. That's one of those things that's difficult to teach or put into a manual unless you are doing it all the time. Glad to help!
anickt
Eugeny Korkhin
on Feb 26, 2015 at 12:25:52 pm
You can Cmd - C to copy and then Alt - V to paste as connected clips. But it does't combine them into secondary, only connects.
Nick Toth
on Feb 27, 2015 at 6:46:22 pm
W will insert into selected secondary at the position of the skimmer (if active) or the playhead
anickt
