Changing all clips with multicam
Tom Sefton
on Feb 18, 2015 at 11:58:33 am
Hi
I seem to be struggling to change the viewpoint of all clips along a project to the same camera angle in multicam. I select them all and hit alt+1 or alt+2 and nothing changes. it only works if I switch them one at a time - is this right.....?
Co-owner at Pollen Studio
http://www.pollenstudio.co.uk
Tom Sefton
Re: Changing all clips with multicam
on Feb 18, 2015 at 12:41:59 pm
Solved it. Simple - highlight all clips then use the metadata tab to change all camera angles.
Brilliant!
Bret Williams
on Feb 18, 2015 at 2:21:47 pm
Maybe also highlight all and right click on them and choose angle there?
Tom Sefton
on Feb 19, 2015 at 11:50:50 pm
This option greys out when you select more than one clip. I can only see the option I listed above as a way to change all angles.
