FCPX can't play GH4 MOV files.
Jeff Kirkland
on Feb 11, 2015 at 12:02:16 pm
Hi All,
Like the title says, I have some GH4 footage, both 4k & 1080p in the MOV format and FCPX only plays back a few frames before the picture freezes and the audio continues.
Quick look can preview the 4k files straight from the SD card so I can't quite figure out why FCPX can't play them. Or is it a format that's not supported without optimisation?
Anyway, this is on a 2013 6 core Mac Pro and the files are stored on a thunderbolt RAID.
Any suggustions appreciated...
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
Brett Sherman
Re: FCPX can't play GH4 MOV files.
on Feb 11, 2015 at 1:38:02 pm
I've noticed the same thing. For me they playback without dropping frames in the timeline, but the images are extremely slow to refresh when skimming (maybe 2 or 3 frames/second). GH4 footage seems to work better with i5 or i7 processors. My MacBook Pro does a much better job. I think this has something to do with built-in H.264 decoding.
Joe Marler
on Feb 11, 2015 at 1:39:19 pm
I have played back and edited 4k and 1080p .mov and .mp4 GH4 material on my 2013 iMac many times without problems in FCP X. At 4k without optimized media it can be a little sluggish if playback (upper right of window) is set to "better quality", but at "better performance" it works smoothly.
I wonder if there's a problem with specific material you're using? If you download 4k GH4 .mov and .mp4 clips from Vimeo can you play those in FCP X? That might help isolate whether it's your specific camera files or a wider problem.
Noah Kadner
on Feb 11, 2015 at 1:54:34 pm
No problems with gh4 clips here on a 2014 MBP via thunderbolt drive. Sounds like possible corrupted clips or a bad drive. What kind of SD cards were you shooting to?
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Jeff Kirkland
on Feb 11, 2015 at 5:02:43 pm
Thanks for the replies,
The footage was recorded to Sandisk Extreme Pro cards, imported to a FCPX camera archive, then brought into FCPX and the Thunderbolt RAID for editing.
What I don't quite get is that OS X has no problem playing the files whether it's using Quicklook, VLC, or whatever - only FCPX is stalling. If the files were corrupted, I'd have expected playback problems to be universal?
Noah Kadner
on Feb 11, 2015 at 7:38:09 pm
I'd try duplicating a clip and playing back from a different drive. Also go through the usual preferences reset etc in FCPX.
Noah
Call Box Training
Joe Marler
on Feb 12, 2015 at 1:39:05 pm
[Jeff Kirkland] " imported to a FCPX camera archive, then brought into FCPX and the Thunderbolt RAID for editing."
That is the only procedural difference between what I've done. Can you try importing a camera file directly into FCP X (without optimization) and see if it makes a difference? I know it's illogical since it should not make any difference.
You could try putting a camera file on your internal SSD drive and experimentally importing from there. Of course that should not make a significant difference vs Thunderbolt RAID but it's something to try.
As one last step, try importing a single clip into a separate test library. If you have only tried a large production library, maybe something associated with that is bogging down your playback.
Jeff Kirkland
on Feb 12, 2015 at 8:33:29 pm
Thanks for the help. Fortunately, I'm testing the workflow before doing any actual production with the camera so I have the luxury af being able to play until I get it right.
I copied everything over to a new library and while, FCPX is struggling, the MOV files do play back as long as I set the viewer to better performance. I shot some test footage as MP4 and these play back just fine even with the viewer output set to best quality.
I can't find any info on the difference between the GH4's MP4 and MOV containers so for now, MP4 looks to be the best option.
I also just updated the GH4 firmware to version 2.1 which says it improves playback of recorded files, so I'll try recording some more MOV files later today.
Ultimately though, I think it might be time to do some archiving, reformatting, and clean installing of my editing workstation. There's nothing quite like a clean sweep to make weird problems go away....
Jeremy Garchow
on Feb 12, 2015 at 5:23:42 pm
[Jeff Kirkland] "Any suggustions appreciated..."
Is it possible to upload a small file?
James Cude
on Feb 18, 2015 at 2:46:54 am
Hey Jeff,
Just curious what frame rate you are shooting? Did you try it out with MOVs vs MP4s?
Regardless, you should report this to Apple on their FCPX feedback page.
http://www.apple.com/feedback/compressor.html
Jeff Kirkland
on Feb 18, 2015 at 11:21:30 am
Ultimately,the playback issue seemed to be a problem with the FCPX library. Moving the project to a new library fixed things, and all subsequent projects seem to be playing fine.
Just for the record, frame rate was 25p but I also tried with 24p. Both MOV and MP4 files refused to play.
I've just chalked it up to one of those weird things that happen from time to time.
Jeremy Garchow
on Feb 19, 2015 at 2:28:26 am
[Jeff Kirkland] "I've just chalked it up to one of those weird things that happen from time to time."
Do you mind if I use this as my signature?
chris king
on Mar 10, 2015 at 12:34:23 am
If you recorded some videos by Panasonic GH4, you may like editing the 4K videos on Mac. Of course, Final Cut Pro is your best choice. With this professional Mac editing software, you can do anything as you want. But, we can’t import Panasonic GH4 4K videos to FCP directly due to the codec incompatibility. As we know, Apple ProRes Codec is the best editing video codec for Final Cur Pro, so we can change Panasonic GH4 4K MOV to Apple ProRes codec (1080p would be the best settings.), which will save you both time and trouble, and all you need is to drag the result videos for prompt editing.
Bob Jordan
on Jun 16, 2015 at 4:18:35 pm
The GH4 recored MOV files are compressed using the h.264 codec, which is final delivery codec and it is not one you want to use for editing. Therefore you first need to transcode GH4 media to a more editing-friendly format, such a Final Cut Pro's ProRes.
Jeff Kirkland
on Jun 16, 2015 at 8:52:20 pm
Agreed, although leaving it as h264 is fine for smaller projects - unless you're using the new Mac Pro. Mine struggles with 4k h264 files while my 27" iMac can open the same project and edit really smoothly.. I think the lack of hardware h264 handling on the Mac Pro makes using Pro Res a pretty much a must on that machine.
