Splitscreen transition plug in
Morten Slemdal
on Feb 10, 2015 at 7:29:36 am
Hi!
I need a splitscreen transition plug in that handles 720/576 footage. I have the one from FCPeffects, but thats for 16:9 only.
Any idea where to get this, With a lot of presets.. I`m just too lazy to do this with transform/Crop/keyframes.
Is it a way to tweak the 16:9 templates from FCPeffects to fit 4:3, in motion (without a lot of work)
John Rofrano
Re: Splitscreen transition plug in
on Feb 10, 2015 at 1:12:34 pm
[Morten Slemdal] "Is it a way to tweak the 16:9 templates from FCPeffects to fit 4:3, in motion (without a lot of work)"
Have you tried to right-click on them and select Open in Motion and then change the project properties to PAL SD and save it as a new template?That might get you what you are looking for.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Morten Slemdal
on Feb 10, 2015 at 2:37:17 pm
Yeah, I tried that, but that doesn't do the trick. It's blue square in the viewer. In 16:9 the square fits the viewer, but in 4:3, it doesn't fit at all.
Jeremy Garchow
on Feb 10, 2015 at 4:34:09 pm
This?: http://www.sugarfx.tv/info/splitter_SUGARfx.html
