Clips in imported XML projects do not sync with library
Roman Semenov
on Feb 6, 2015 at 11:35:52 am
When I import XML project its clips are not marked as 'used' in Library.
I'm trying to import an unfinished project from Premiere. First I import all media so that all media is tagged with folders and all unused media is present in library. Then I import xml sequence (using DaVinci to convert xml to fcpxml). Now I want to tag all used clips as favorites but the library does not show any clips as 'used'. When I click on timeline clip and select 'Reveal in Browser' it jumps to correct clip. Is there a workaround?
Bret Williams
Re: Clips in imported XML projects do not sync with library
on Feb 6, 2015 at 2:55:04 pm
Do you have the function enabled?
Roman Semenov
on Feb 6, 2015 at 5:49:52 pm
What function?
Bret Williams
on Feb 6, 2015 at 6:06:37 pm
The one you're looking for. Show/mark used media. It's off by default.
Bret Williams
on Feb 7, 2015 at 5:26:25 am
View>show used media ranges
