Set exact volume in timeline / adjust volume to more than one clip
Morten Slemdal
on Feb 5, 2015 at 7:59:08 am
I have a keyframe and I want to give it an exact db; can I do that in the timeline with a shortcut?
How can I adjust volume to more than one Clip?
Jeremy Garchow
Re: Set exact volume in timeline / adjust volume to more than one clip
on Feb 5, 2015 at 2:08:57 pm
You can do this in the inspector, but not one keyboard shortcut.
You can set an absolute level for each selected clip, and relative level. I have those mapped to control-command-l and control-l respectively.
You can also select clips and hit control-plus and control-minus to adjust the relative levels of the clips by 1db.
Morten Slemdal
on Feb 5, 2015 at 2:16:01 pm
Ok, thanks
