Limit transform in a particular area
Devin Christy
on Feb 2, 2015 at 5:48:03 pm
How to limit transform (scale, rotate, position) inside a particular area. I needed to show picture animation (scale, rotate, position) with a background of a TV. I mean inside the TV screen. But the problem is when i make transform to the photos, it is coming outside the TV screen. Any way to fit the transform to fit inside that particular area?
Thank You
Noah Kadner
Re: Limit transform in a particular area
on Feb 3, 2015 at 6:47:39 pm
A screenshot would be a big help to understand what you're after. But you can next compositions within Compound Clips and use the crop tool as well. Also for deeply complex animations, I highly recommend using Motion.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Jeremy Garchow
on Feb 3, 2015 at 7:19:34 pm
It would be best to make a matte, which is to say, cut a "hole" in the TV and composite the photo underneath.
