Fcpx multicam audio echo or phase issues with two lavalier mic's
Mick Bezem
on Feb 2, 2015 at 6:56:25 pm
As a dutchmen I try to explain in my best englisch what kind of problem I have with my audio in FCPX. I recorded an interview with two persons. Person 1 and 2 both had a lavalier mic, from person 1 the audio go to camera A and from person 2 go audio to camera B. When I import the material and i'm make a multicam clip it syncs fine. But I want to hear the audio from both persons (camera's) at the same time. The problem that I have is that it sounds not what it should be, like there is a phase problem. What happen is that you can hear the voice of person 1 also softly in the mic from person 2 and vice versa. But is that the problem? Do I have to sync the audio more precisely? I've already make it dual mono but this doesn't do the trick. Does someone has an idea what to do to make it a good audio mix from both camera's?
