FcPX 10.1.3 Sloooooooow Export
Will Granzier
on Jan 20, 2015 at 3:17:18 pm
Hiya All
I have a small project around 26 min that has been shot in AVCHD 1080i and been edited on Pro Rez. i have made Proxy media of all the files.... When I try and export the project, it would take forever and a day - Ummmmm About 6 hours.... At times it would hang at different part of the project but it would eventually export -- EVENTUALLY !!!
Im running an 2.5 Imac with 10.9.3 - 16 Gigs of Ram
I have a WD thunderbolt duo drive - So the system is not slow
There are no MAJOR effects in the time line just a few keys added. Any ideas as to how to get this one resolved ?
Thnx in advance
Will Granzier
Eric Santiago
Re: FcPX 10.1.3 Sloooooooow Export
on Jan 20, 2015 at 6:00:37 pm
You try exporting as Master?
Will Granzier
on Jan 21, 2015 at 5:36:06 am
Hi
Ya thats what I am doing..... Ive NEVER had this. a 30m programme would be export in a bout 15 to 20 min usually
Eric Santiago
on Jan 22, 2015 at 2:28:11 pm
Remove the proxies and see if you can export to Master from that end.
Ive had proxies get corrupt on me due to bad crashes.
you def have a rendered timeline correct?
before exporting I sometimes make sure that there are no lingering un-rendered clips.
