Share to DVD keeps hanging at about 62 percent
Mark Suszko
on Jan 16, 2015 at 5:52:29 am
SD footage under two hours long, hit "share to DVD", everything seems to go great, but progress hangs right around 62 percent. Is this a common problem? My FCP7 setup is handling the exact same job, sharing right off the timeline, without a problem, while I try to figure out the problem with the FCPX version.
Brian Thomas
Re: Share to DVD keeps hanging at about 62 percent
on Jan 17, 2015 at 10:51:56 am
I can't offer any solution but if that happened to me I'd trim the timeline down to about 55% and see if that exports OK. Then I'd try the other part of the original and see where that gets stuck. After that then I'd steadily zoom in on where the problem seems to be.
Just because it works in FCP7 doesn't make it at all certain it would work elsewhere. I believe FCPX is a complete rewrite.
Sharing to DVD never worked satisfactorily for me. I gave up with that option and now I create a 'Master' (I need that anyway for my archive) and then use it in my DVD authoring software which in my case is Adobe Encore.
FCPX and PPro 6. iMac 24 + MBP 17". Near Geneva, Switzerland
