Change playback time to duration instead of timecode?
Bryan Tarnowski
on Jan 14, 2015 at 8:09:13 pm
Hi, I am wondering if it is possible to view an audio file's timecode as duration of that file, as opposed to the timecode? Specifically when skimming through audio in the browser window.
I have audio recorded via a Zoom H4n, that has been transcribed and translated. The transcription was done using duration time stamps so I am looking for an easy solution to find those time stamps in FCPX so I don't have to do the math in my head every time I'm skimming for a particular quote (yes, my fault not to specify this ahead of time).
Thanks for any help
Bryan
Bret Williams
Re: Change playback time to duration instead of timecode?
on Jan 14, 2015 at 11:53:06 pm
I do this all the time. Best thing to do is to drag out a range. Mark in at the head, and drag the outpoint of the range and it will give you the duration right there next to the mouse pointer.
Bryan Tarnowski
on Jan 15, 2015 at 3:06:21 am
Beautiful. Thanks Bret.
