FCPX stuck in a render loop?
Matt Whittemore
on Dec 20, 2014 at 2:54:55 pm
Hi, FCPX is constantly rendering, going from 0% to 100% over and over. See video:
https://vimeo.com/115056209
It only does it when in a certain project. Has anyone had this issue? Two different Apple support tech were of no help.
Thanks for any input.
Jeremy Garchow
Re: FCPX stuck in a render loop?
on Dec 20, 2014 at 3:57:20 pm
What have you done to troubleshoot so far?
Jeff Kirkland
on Dec 20, 2014 at 6:45:08 pm
I had this happen in a project this week. A constant loop doing a background render. Deleting the render files didn't help. From memory, I selected all, cut it from the timeline (cd-x), deleted all render files, then pasted the timeline back.
I suspect a bug.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: http://gplus.to/jeffkirkland | Twitter: @jeffkirkland
John Pale
on Dec 20, 2014 at 6:58:51 pm
Happened to me too. I cut and pasted everything to a new timeline. That solved it.
Matt Whittemore
on Dec 21, 2014 at 3:02:12 pm
I'm sorry I should have stated what I did to troubleshoot. I did the following:
Trashed preferences
Deleted all the render files and re-rendered
Repaired disk permissions
Waited 22 hours to see if it was just rendering
Disabled a plugin (CoreMelt Lock & Load) that I thought may be the culprit
Copied all clips to a new project, in a new library
I just tried cutting everything from the timeline, deleting render files, then pasting back, to no avail.
Jeremy Garchow
on Dec 22, 2014 at 3:58:28 am
What is your source material and do you have any plugins or motion templates (besides the ones you mention)?
What happens if you turn background render off?
Jeff Kirkland
on Dec 22, 2014 at 6:47:48 am
I can say in my case it was an endless loop trying to render the standard FCPX cross fade. Turning of background render obviously stopped rendering and thus stopped the loop but a manual render would also loop once it hit that one dodgy transition.
As has been said, cutting and pasting the entire project seemed to fix it. It is possible that I did create a new project to paste into but I don't remember doing that - I think I just pasted back into the existing one.
Chic Scaparo
on Aug 3, 2015 at 3:15:26 pm
Hey Matt,
Did you have any luck figuring out what caused the loop? I'm currently in the same predicament.
Chic Scaparo
