can I do a keyword analysis?
Jenn Lindsay
on Dec 15, 2014 at 10:13:28 pm
I just painstakingly keyworded 51 hours of footage, much of it rather dense interviews. I did stream-of-consciousness keywording just to get it all logged. But now I have tons of keywords, many of them a bit redundant (eg, some clips keyworded under 'reductive' and others under 'reductionism'). I'm wondering if there is a way I can do a keyword analysis where I can see what terms are keyed most frequently. Also, is there a way to create thematic keyword groups for words that belong together?
It would be really dreamy if I could play around with my keyword groups in some way.....
Thanks!!
http://www.JennLindsay.com
iMac 27-inch, 3.5 GHz Intel Core i7. 4GB GPU.
FCPX
Bob Woodhead
Re: can I do a keyword analysis?
on Dec 15, 2014 at 10:55:43 pm
You could create "top level" keywords to group related keyword clips.
And don't forget about Smart collections; "show me clips with top-keyword "A" AND sub-keyword "g" AND keyword "good soundbite". I find Smart collections are incredibly useful as the # of clips increase. My template Library (a Library that contains some often-used graphics and Smart and regular keywords) has Smart collections called; Timelines (which are projects - snapshots), Comps (grouped clips), Stills, Audio, Multicam, and Unused.
I didn't answer your question, but perhaps helped in another way.
Bret Williams
on Dec 16, 2014 at 1:58:27 am
All great ideas.
You could select the two redundant keywords in the browser, which would display both sets as a whole, and then apply the desired keyword to them all. Then simply delete the undesired keyword.
You can make groups by smart collections, or by making folders and putting related keywords in the folder. Then just select the folder.
Noah Kadner
on Dec 16, 2014 at 3:36:42 am
You could also wash your event through Shot Notes X and see if you can't organize into larger buckets-
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Jenn Lindsay
on Dec 18, 2014 at 2:58:23 pm
Thanks to both of you very much!
Do you know where I can learn more about the smart collection capacity?
I really wish there was a feature where they could show you your hierarchy of keywords or do a keyword analysis......it would really help with rough cuts and story building!
FCPX
Bob Woodhead
Why, yes, there is a Santa, and he's called Andreas Kiel
on Dec 18, 2014 at 11:53:57 pm
Odds are there's some Smart Collection tutorials on MacBreak Studio. But they're pretty self-explanatory, and identical in nature to Smart Playlists in iTunes.
HOWEVER, a bit of searching the pasture found THIS: https://forums.creativecow.net/thread/344/25129#25129
Aka, the LittleKeywordExtractor !
I just tested it, and it should do just what you need. Take the output of LKE and open in a spreadsheet, database, whatever. It's a comma-delimited file of keywords and timecode.
Jenn Lindsay
Re: Why, yes, there is a Santa, and he's called Andreas Kiel
on Dec 19, 2014 at 4:27:47 pm
Dude! This is amazing! Thank you so much!
FCPX
