Sharing Libraries without needing to relink
Loren Risker
on Dec 5, 2014 at 9:31:42 pm
I have a library with 7 events and over a thousand clips, some of which are AVCHD, which is slow to relink.
I have an exact copy of the media on 2 different drives, one for me and one for my producer.
All of the media, cache, proxies, etc are outside of the library so that we have a very small library.
The problem is, when we send the library back and forth it takes a long time to reconnect all the media, like over an hour.
I've considering naming the hard drives the same name (haven't tested yet but will once the relink finishes) but I was wondering if anyone has found a better solution?
We're mostly using this to make notes on the project file, so it's very tedious to have to relink everything just to get back up and running.
Am I missing something?
OutOfFocus.TV - Original series, music videos, mini-docs.
Eugeny Korkhin
Re: Sharing Libraries without needing to relink
on Dec 5, 2014 at 10:39:27 pm
Hi
Identical names of drives and matching folder structure should help.
Loren Risker
on Dec 6, 2014 at 12:25:11 am
The names are identical, the drives are cloned.
Renaming the volume so they have the same name worked. I guess that will have to work, but I can see this leading to frustration when I had the drive back.
Loren Risker
on Dec 6, 2014 at 12:27:58 am
Except it won't reconnect the proxy media. Aaargh, so close.
