Color Correction Workflow on Multiple Multicam Projects
Jeff Krieger
on Dec 4, 2014 at 6:30:07 pm
Just curious...when do you do your color correcting? I have broken up a 20 min piece into multiple multicam projects. Is it best to color correct at the event level before I bring it into the project timeline? Before I create the multicam project? Or at the very end? Just curuious. Thx!
Patrice Freymond
Re: Color Correction Workflow on Multiple Multicam Projects
on Dec 4, 2014 at 6:39:03 pm
I tend to do the CC after cutting the piece, thus avoiding CCing takes that I don't use.
FCPX makes it very easy to open each multiclip and CC each angle.
And since you can go back and forth between the cut and the multiclip with shortcuts it sort of compensates for the absence of a multiple screen display in the UI (à la FCP...7)to match your shots.
just my 2 cents
Patrice Freymond
Editor  Certified Trainer FCPX 10.1.3
Post Consultant
Always learning...
