Can you archive events?
Josephine Macaulay
on Dec 3, 2014 at 9:29:27 pm
I have a main library that has a number of events in it that I no longer need to access regularly, but don't want to get rid of. Is there a way to archive them, or create another folder to put them in, so I don't have a long list of events to scroll through in the library pane? I'm using 10.1.3. Thanks!
Noah Kadner
Re: Can you archive events?
on Dec 3, 2014 at 11:54:30 pm
You can drag an event to a new Library and then archive that...
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Tim Jones
on Dec 4, 2014 at 5:32:08 am
The simplest mechanism would be to create a new Library and then move the old events into that library, removing them from your working library. Next, simply right click and close that library.
Tim
Tim Jones
CTO - TOLIS Group, Inc.
http://www.tolisgroup.com
BRU ... because it's the RESTORE that matters!
Mark Suszko
on Dec 4, 2014 at 2:21:53 pm
He wants to offload that library, I think, to another drive for safekeeping, no longer on the system.
Bret Williams
on Dec 4, 2014 at 2:30:32 pm
Sounds to me like she's been doing all his projects/jobs in one library with an event for each job and now he simply needs to offload/close the projects he's not working on.
Josephine Macaulay
on Dec 5, 2014 at 12:51:18 am
Thanks all for the suggestions. Creating a new library, moving the old projects into it and closing the library works just fine.
"He" is a she, by the way ;)
Thanks!!
Bret Williams
on Dec 5, 2014 at 3:16:38 am
Fixed! :)
