Indulge a FCPX noob for a moment please
Daniel Frome
on Nov 24, 2014 at 3:24:12 pm
Let's pretend I have two segments in a sequence, "SEG A" and "SEG B" which run one after another. I have a music track under SEG A, and a different music track under SEG B.
If I cut a section of SEG A, The underlying music remains extended, and now overlaps the music from SEG B.
Is there an easy way to automatically have the music under SEG A shorten, alongside any edits that I make to SEG A?
Noah Kadner
Re: Indulge a FCPX noob for a moment please
on Nov 24, 2014 at 3:49:05 pm
You could do this with a compound clip but that would make the sequence editing less flexible. I'd suggest lasso edits instead.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
John Davidson
on Nov 24, 2014 at 5:34:05 pm
I use option+right bracket (or left, depending on your needs) constantly with things like this.
John Davidson | President / Creative Director | Magic Feather Inc.
Bob Woodhead
on Nov 24, 2014 at 6:14:33 pm
If you're cutting from the end of Seg A, you could blade-all. Then select the end of Seg A, delete, and any connected clips on the end of A will go 'poof'. 3 keystrokes. Shift-Cmd-B, C, Delete.
PS - any connected clips that get bladed this way automatically re-connect to the 1st frame of the newly bladed Primary clip, which is why they go poof when primary is deleted.
Mark Smith
on Nov 24, 2014 at 11:39:31 pm
This is a tricky question, no? you are cutting picture and expecting a music cut to be in the right place hen you make the picture cut?
Craig Alan
on Nov 25, 2014 at 3:53:15 am
With snapping on and magnetic behavior, not hard to trim the attached audio to new edit point.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
