Adjusting color temperature in FCPX
Claude Lyneis
on Nov 19, 2014 at 5:02:41 am
Is there a tutorial that shows how to shift the color temperature in FCPX in an equivalent way to how it is done in Aperture or other programs? Before shooting, it is easy to adjust my Canon XA20 using a white or gray sheet and having the camera set the white balance, but that doesn't always get done. I guess in FCPX color window it might be offsetting the global color circle to the red or blue, but I am not sure that has the same effect.
Jeremy Garchow
Re: Adjusting color temperature in FCPX
on Nov 19, 2014 at 12:13:02 pm
There isn't a color picker or temperature slider, but check out Hawaki AutoGrade. It helps with white balance (and more).
http://hawaiki.co/autograde.html
Scott Witthaus
on Nov 20, 2014 at 11:55:52 am
One thing that I have found that works pretty good is the Color Balance feature in Inspector. I find a lot of DSLR footage leans towards the yellow, or warm side. The Balance option will do a nice job (on a case by case basis) of giving you a base starting point and getting colors back to more "true". Give it a shot and see what you think.
Scott
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
