Transition split screen - first make compund clip?
Morten Slemdal
on Nov 18, 2014 at 8:18:07 am
Is that the way to go?
Bret Williams
Re: Transition split screen - first make compund clip?
on Nov 18, 2014 at 4:44:49 pm
Or put the incoming clip above the two clips of the split screen and add the transition solely to the incoming clip. Especially say a dissolve. Other effects may give different results depending on if they're designed to overlay or incorporate the background.
