Duplicate Project
Sergio Lelevier
Duplicate Project
on Nov 17, 2014 at 2:31:06 pm
What's the best way to duplicate a project, in order to edit a diferent version of the original. And keep the original version.
Bret Williams
Re: Duplicate Project
on Nov 17, 2014 at 3:24:55 pm
Either do a snapshot of the project or duplicate the project.
The advantage of the snapshot feature is it will lock everything in time at that moment. If you do a simple duplicate and have things like compound clips, then any changes to the compound clips will also change universally, throughout all instances of the compound in all versions of the project. Which might be something you want. Snapshots will lock the compound clips where they are, as their own instance.
I've switched to snapshots myself.
Jeremy Garchow
on Nov 17, 2014 at 4:37:58 pm
[Bret Williams] "I've switched to snapshots myself."
Me too. Even modified the keyboard shortcut to command-d.
Jeremy
Charlie Austin
on Nov 17, 2014 at 9:08:54 pm
Me three... Snapshots along the way, make all changes to original. Once a version 1 is locked, duplicate that as a snapshot and that snapshot becomes the "master" until I hit V.2 etc...
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
James Ewart
on Nov 22, 2014 at 1:32:16 pm
Do snapshots use much more storage space?
