Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
Josh Birch
on Nov 13, 2014 at 3:07:36 pm
Hi Guys,
What is the highest possible export option with an mpeg-4 container (.mp4) with a H.264 codec. My client is asking for this format but can't figure it out?
When I go to Export > Master File it only gives me an option for .mov container with H.264 codec....
Thanks in advance
Josh
http://www.josh-birch.co.uk
Paul Figgiani
Re: Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
on Nov 13, 2014 at 4:51:56 pm
[Josh Birch] "Hi Guys,
Thanks in advance
Josh"
You need to set this up in Compressor. One option is to built a Setting's Preset using QTExport Components - Encoder Type:MPEG-4 ... and then customize by pressing the "Configure" option.
-paul.
Patrice Freymond
on Nov 13, 2014 at 7:49:19 pm
I don't have fcpx in front of m but if I make no mistake you can create an mp4 file using the "Apple device" setting. One of the submenus will give you the possibility to chose "Computer" and this creates a non .mov h264 file.
Could be a solution to your problem without goint to Compressor ?
Patrice Freymond
Editor  Certified Trainer FCPX 10.1.3
Post Consultant
Always learning...
