Library comes up empty
Jason Jenkins
on Nov 6, 2014 at 6:53:45 pm
I have an older project that I updated to work in FCPX 10.1.3. Then I made the mistake of moving it from the disk image onto my RAID using the finder instead of FCPX. Now I can open the library in FCPX, but neither event nor media shows up. FCPX sees it as an empty library. How do I fix this?!
Jason Jenkins
Flowmotion Media
Video production... with style!
Check out my Mormon.org profile.
Andy Neil
Re: Library comes up empty
on Nov 6, 2014 at 7:03:08 pm
Have you tried opening the library in the finder to see if the media is actually gone or if you just have a corrupt .fcpevent file?
Also, if you moved from a disk image to a RAID the default would be a copy, so does that mean you still have the disk image with the original library?
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Jason Jenkins
on Nov 6, 2014 at 7:10:25 pm
[Andy Neil] "Have you tried opening the library in the finder to see if the media is actually gone or if you just have a corrupt .fcpevent file?"
It looks like everything that should be in the library is there.
[Andy Neil] "Also, if you moved from a disk image to a RAID the default would be a copy, so does that mean you still have the disk image with the original library?"
I moved, didn't copy. But I did save the old events and projects folders.
Jason Jenkins
Flowmotion Media
Andy Neil
on Nov 6, 2014 at 7:50:07 pm
Well, I suppose you could re-open the old event and reconvert it for 10.1.3 use and then just steal the .fcpevent file to put in the library on your raid? Maybe that'll help.
[Jason Jenkins] "I moved, didn't copy."
At the very least this should be a abject lesson on the benefits of copying over moving.
Andy
Jason Jenkins
on Nov 6, 2014 at 10:11:24 pm
[Andy Neil] "Well, I suppose you could re-open the old event and reconvert it for 10.1.3 use and then just steal the .fcpevent file to put in the library on your raid? Maybe that'll help."
Thanks, Andy! Got things sorted.
Jason Jenkins
Flowmotion Media
Bret Williams
on Nov 6, 2014 at 8:48:05 pm
What hot key is it to move instead of the default copy? Wait... I don't want to even know!
