Unable to backup FCPX library package?
James Culbertson
on Nov 5, 2014 at 7:49:02 pm
I am trying to copy a large FCPX library package from one Pegasus R4 8GB array to another identical Pegasus array to free up space. The copy fails part way through whether I am doing a finder copy or using Chronosync. I have tried other library packages with similar results. I get an error -50 some of the time.
I am running Disksomnia. I have not had this problems before.
Any suggestions?
OSX 10.9.2 on a new Mac Cylinder.
Jeremy Garchow
Re: Unable to backup FCPX library package?
on Nov 5, 2014 at 8:38:56 pm
How big is the Library and what's in it?
James Culbertson
on Nov 5, 2014 at 9:24:11 pm
It's more than one library. One is in the 300GB range the other in the 600GB range... just AVCHD (and some GoPro) interview footage for the most part.
Jeremy Garchow
on Nov 5, 2014 at 11:00:53 pm
First, I would delete the cache and try again.
If that doesn't work, I'd try and use FCPX to make a new library on the destination drive, and then consolidate the media to the new drive/Library.
Jeremy
Charlie Austin
on Nov 6, 2014 at 3:05:12 am
[James Culbertson] " I get an error -50 some of the time."
Well, For what it's worth, here's what that is...
paramErr = -50, /*error in user parameter list*/
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Jeremy Garchow
on Nov 6, 2014 at 3:28:42 am
I think 10.9.3 was supposed to clear this up, but I can't remember.
James Culbertson
on Nov 6, 2014 at 5:42:23 pm
[Jeremy Garchow] "
I think 10.9.3 was supposed to clear this up, but I can't remember."
I just read that 10.9.2 has some kind of copy bug that Apple has acknowledged. I'll go to 10.9.5 when I have the chance and see if that fixes things.
James Culbertson
on Nov 7, 2014 at 12:57:51 am
10.9.5 did not fix things. I cannot copy large files to or from either Pegasus array or to or from any other external drive (via thunderbolt, USB3, or Firewire).
I can copy between other external drives without issue.
In the near term I am going to have to work off of a portable La Cie Rugged Thunderbolt drive.
Jeremy Garchow
on Nov 7, 2014 at 1:14:48 am
Wait, this drive won't accept large files at all? This isn't localized to just one Library?
Sorry, your post is confusing.
James Culbertson
on Nov 7, 2014 at 1:22:45 am
[Jeremy Garchow] "Wait, this drive won't accept large files at all? This isn't localized to just one Library?"
Ah, sorry. This is all finder related copying (not internal FCPX). I also tried using ChronoSync as that has sometimes been more dependable in the past. It effects multiple FCPX library packages on both drives (not sure if it is all libraries). I also cannot copy large AVCHD archives onto the drives at this point. ...waiting to hear from Promise tech support.
Jeremy Garchow
on Nov 7, 2014 at 2:47:12 am
Are the drives formatted as OS X extended?
James Culbertson
on Nov 7, 2014 at 3:03:23 am
[Jeremy Garchow] "Are the drives formatted as OS X extended?"
All of my drives including the Pegasus are Mac OS Extended (Journaled).
Most of the camera archive sneakernet drives are OSX Extended and 2-3 are NTFS. All of my drive dock backup disks are OS X Extended.
The key thing is my problems are a recent occurrence of the last two weeks or so. I've been working with all these drives for at least 6 months with no issues, one of the Pegasus arrays is a year old.
Craig Alan
on Nov 9, 2014 at 3:00:22 am
Call Pegasus technical support.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
James Culbertson
on Nov 11, 2014 at 6:24:19 pm
I sent Pegasus a service report for my two drives and they responded:
"One-bit ECC error was detected"
I've replied with a query asking them to give me some advice on what to do about it. ;-)
Craig Alan
on Nov 11, 2014 at 7:04:12 pm
call them. with Earbuds in ears and system in front of you.
