Seeking Support with Exporting from FCP 10.1
Adrian Quintero
on Oct 24, 2014 at 8:24:53 pm
Hello,
I have an older version of FCP X- 10.1 I am working with a client and in need of some help! Been searching on line and can't quite find the answer.
I brought on some footage that had been posted to my client's Vimeo page, so they are small .mp4 files, already compressed. Small changes are needed to be made-mostly cuts to the beginning and end of the clips, and some audio boosting. No transitions or anything else added.
I have MANY of these videos to trim and boost audio too, each about 1 hour each.
What would you all suggest is the fastest way to export the video with the changes I'm making? I don't want to re-compress it, and can't figure out the right export settings to keep it the same quality I brought it in as.
Thank you so much,
Adrian
Robin S. Kurz
Re: Seeking Support with Exporting from FCP 10.1
on Oct 25, 2014 at 2:41:41 pm
There's no way of exporting an H.264 without recompressing. It's a Long GOP format. Simply use a high data-rate. Any of the "Apple Devices" presets should be fine.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
