Global Change ?
joe zabrosky
Global Change ?
on Oct 20, 2014 at 7:43:11 pm
After 32 band equalizing one clip in the graphic equalizer in the audio enhancement section of fcpx is there a way to globally equalize hundreds of audio clips with the exact same equalization i made to the first clip just mentioned. Or, do i have to go into each of the 100s of clips and make the changes manually?
I have used the match tool to match the overall sound of a clip to various other clips but it appears that the match tool does not allow me to match the exact 32 band equalization i do to 1 clip. Am I correct in saying this or wrong? Boy, do I hope I'm wrong.
Thanks, joe
joseph zabrosky
Mark Smith
Re: Global Change ?
on Oct 20, 2014 at 8:53:08 pm
Copy original clip then, select other clips in the time line index, then paste attributes, tick off the audio check box . Done?
joe zabrosky
Re: Global Change ?
on Oct 21, 2014 at 7:31:19 pm
Thanks Mark - I should have known that. Thanks again!
joseph zabrosky
