View audio roles on meters (bussing)?
Trevor Asquerthian
on Oct 16, 2014 at 10:18:58 am
I'm back on FCPx again after a little while away...
Is there any way yet of metering roles?
i.e. I'd like to see say an 8 channel audio meter where 1&2 are full mix, 3&4 are 'dialogue' roles, 5&6 are 'fx' roles and 7&8 are 'music' roles
This way I'd be able to get a quick check as I'm building a sequence that my roles are correctly assigned - at the moment I'm having to export a multichannel QT to reimport and check all is good.
Robin S. Kurz
Re: View audio roles on meters (bussing)?
on Oct 16, 2014 at 11:30:38 am
[Trevor Asquerthian] "that my roles are correctly assigned"
Either: open the timeline index and select a role. They will highlight.
Or: Simply set the timeline clip appearance settings to show Clip Roles.
[Trevor Asquerthian] " I'd like to see say an 8 channel audio meter"
There is no mixer in that sense in X. You can click and scale the audio meter in the dashboard and use the roles to selectively mute each group as needed.
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Andy Neil
on Oct 16, 2014 at 5:14:05 pm
Not in the way you're suggesting, but you can isolate specific audio roles by opening the Index (CMD+SHIFT+2) and clicking on the roles tab, then unchecking all but the role you want to monitor. If you also select the role in the index you'll be able to see them highlighted visually in your timeline so you can make a visual inspection of them as well.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Robin S. Kurz
on Oct 16, 2014 at 5:18:01 pm
Coulda sworn that's what I wrote. :D
Trevor Asquerthian
on Oct 16, 2014 at 10:04:41 pm
Yes, thank you to both of you. (Although it's a bit too clunky to work turning them on and off via the timeline index)
Robin S. Kurz
on Oct 17, 2014 at 7:49:44 am
Whereby if you hold the ⌥-key when clicking, that will solo that particular role. Should that make any difference in the "clunkiness".
Trevor Asquerthian
on Oct 17, 2014 at 10:41:36 am
Great to know another shortcut, thanks... still laggy, unfortunately.
Stops the timeline and then it's a couple of seconds before I can play again
Then found that the only way to 'unsolo' was to 'mute all' with CMD+click, then 'unmute all' with CMD+click again - which adds 4-5 seconds, sometimes with pinwheel. This is on a very small sequence.
Don't get me wrong, it's usable; but room for improvement...
