AVCHD 50p not Optimized
Eric Sternberger
on Oct 16, 2014 at 8:48:40 am
we got a problem with footage originating from a Sony FS700 shot in 50p. The samurai on the camera didn´t run, so we have to use the media on the internal card.
But: The AVCHD 50p does´t play smooth at all (on a 2013 Mac Pro with dual700)
So we ingested again with optimizing media checked. But: FCPX doesn´t use the optimized clips, though they are being transcode during ingest and put in the Transcoded Media Folder.
I´m stumped, because some B-Roll Canon footage just works fine..
what are we missing??
Robin S. Kurz
Re: AVCHD 50p not Optimized
on Oct 16, 2014 at 10:06:17 am
[Eric Sternberger] "But: FCPX doesn´t use the optimized clips"
How do you know this?
[Eric Sternberger] "they are being transcode during ingest"
Which obviously has to finish before it can be used, yes. What does the background tasks window have to say about the matter??
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Eric Sternberger
on Oct 16, 2014 at 10:35:24 am
They are finished transcoding.
The Info on the Video-Tab shows avchd instead of prores.
they don´t play. ProRes clips do play.
Bret Williams
on Oct 17, 2014 at 2:51:19 am
Info always shows the format of the originals.
gary adcock
on Oct 17, 2014 at 12:06:32 am
[Eric Sternberger] " from a Sony FS700 shot in 50p. The samurai on the camera didn´t run, "
Thats because 50p or 60p frame rate is not supported in 1080 on the Samurai.
"The AVCHD 50p does´t play smooth at all (on a 2013 Mac Pro with dual700) "
TOO much overhead to play back the files, what storage are you using- needs to be pretty fast to support that frame rate
"I´m stumped, because some B-Roll Canon footage just works fine..
betting the Canon footage is 50i not 50p
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
Follow my blog at http://www.garyadcock.com
Or follow me on Twitter
@garyadcock
Mark Morache
on Oct 17, 2014 at 3:52:18 am
I'm curious about the fact that you can't play the avc-hd streams.
I did a project earlier this year that was shot on a FS-700 where the guy shot avc-hd 100, and I was able to edit it, no problem.
The bitrate is about 116 Mbit/s, and I'm not even on a raid, just an single e-data drive.
I found that I could even handle two of the fat streams when I has better performance selected in FCPX.
Why can't you play the 50 Mbit/s video.
I'm on an old 2010 MBP.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
Eric Sternberger
on Oct 17, 2014 at 9:08:49 am
the problem is not the samurai. It did not run because of a misconfiguration by the DP…
So we had to use the SD-Cards with AVCHD-Codec….
But I´d like to know: Is an up to date Mac not powerful enough to play 50p AVCHD?
We are storing the Media on a Pegasus R6 TB2 Raid. That sports over 500 mb/sec…
Even in ProRes 50p is roughly 40 mb/sec...
I heard about problems with 50p when FCPX came out. But usually we shoot 50i because we deliver broadcast specs, so we never ran into this…
There is optimized Media in the Transcoded Media Bin. When we open that with Quicktime or mfx4mac it plays fine. In FCPX it´s just crap...
So, is FCPX the problem? A wrong configuration. Or is there anything wrong, at all?
