Shortcuts
James Ewart
Shortcuts
on Oct 13, 2014 at 3:03:48 pm
Anyone know a sneaky shortcut for option dragging a clip into the layer above to create a duplicate?
I don't even know what the command is called.
Thank you
Jeremy Garchow
Re: Shortcuts
on Oct 13, 2014 at 3:07:13 pm
Select the clip with c.
Command-c. (copy)
Option-v (paste connected).
If not, then you hold option, click and drag the clip up.
Robin S. Kurz
Re: Shortcuts
on Oct 13, 2014 at 3:42:43 pm
[Jeremy Garchow] "hold option, click and drag the clip up."
Probably the easier/better option, yes. ;)
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
James Ewart
Re: Shortcuts
on Oct 13, 2014 at 5:12:06 pm
I find option drag a bit tedious. Thus the OP. I guess I'm hard to please.
Feature request "Duplicate as Connected clip"
Robin S. Kurz
Re: Shortcuts
on Oct 13, 2014 at 5:25:57 pm
[James Ewart] "I find option drag a bit tedious."
Uh-huh. Okay.
[James Ewart] "Feature request "Duplicate as Connected clip""
There's always ⌘C and ⌥V.
Bret Williams
Re: Shortcuts
on Oct 15, 2014 at 12:34:05 am
It's definitely still annoying that you can't combine option drag with shift to keep the duplicate from moving horizontally. Instead you have to rely on snapping or the visual +/- cue (which gives bizarre results sometimes dragging from a secondary. In FCP legacy I always held shift and the muscle memory won't go away. If you hold shift it cancels the duplication.
Jeremy Garchow
Re: Shortcuts
on Oct 15, 2014 at 1:14:53 am
Copy paste connected is my go to move.
Mark Morache
Re: Shortcuts
on Oct 15, 2014 at 1:31:13 am
Likewise, I copy, and paste with option-v to add the connected clip.
I just make sure I'm parked at the start of the clip I'm copying so the copy ends up in the same place, and not half way down.
Doing the option-drag to make a copy, I like that I get a window giving me feedback of how much the clip is displaced, making it pretty easy to slide left or right until the window displays 0:00.
I agree that adding the ability to press "shift" would make things easier.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
