Avchd, 50i footage - project settings, transcode?
Morten Slemdal
on Oct 9, 2014 at 6:08:10 pm
I have a digital camera with footage shot in avchd, 50i. When I drop it on a project in fcpx, the project is 50p. I'm going to screen it from QT on a tv, directly from my mac - mirrored - or is it a better way? Dvd? Should I change to 50i under project settings?
Should I transcode? Uggggh - confused!
Ronny Courtens
Re: Avchd, 50i footage - project settings, transcode?
on Oct 9, 2014 at 8:38:27 pm
50i = 25fps.
If you are going to play this from QT player it is best to set your project settings to 25p.
If you are going to make a DVD it is best to set your project settings to 25i.
- Ronny
Morten Slemdal
on Oct 9, 2014 at 8:56:39 pm
Ok, thanx.
And transcoding is just for the workflow? If the system handles my editing, I don't have to transcode. It doesn't influence the Finished result?
Ronny Courtens
on Oct 9, 2014 at 10:03:42 pm
If your system handles your footage natively you don't need to optimize it to prores. This won't affect the quality of your final master.
- Ronny
