Finally upgraded to 10.1.3 now some internal compound clips I had rotated are distorted
Shaun Gilmer
on Oct 9, 2014 at 3:30:52 pm
I finally upgraded to 10.1.3 from an older FCPX and imported everything. I then go to open up the template for our Church's announcement videos to update them and now some internal compound clips I had rotated are distorted. I tried to reimport, delete render files, and adjust all the effects, nothing fixes it. Please help I really do not want to have to rebuild these custom animations, I had them perfect. I just have some basic compound clips rotated then animated to swipe across the frame. Nothing had changed besides FCPX so I am confused.
Here was a still before:
https://www.dropbox.com/s/1vljxq6m9muvj3b/before.png?dl=0
After upgrade:
https://www.dropbox.com/s/o7d61st0hrvnyv8/after.png?dl=0
If you try to fix the simple rotation:
https://www.dropbox.com/s/06ocp5m36uhslcf/whilefixing.png?dl=0
Ronny Courtens
Re: Finally upgraded to 10.1.3 now some internal compound clips I had rotated are distorted
on Oct 9, 2014 at 5:25:41 pm
Sorry to hear you are having these issues.
So if I get this right you have opened the compound clip in its own timeline and there you select the green veil clip and you are not able to rotate this clip. Is that correct?
- Ronny
David Mathis
on Oct 9, 2014 at 5:51:59 pm
Could it be possible some settings were changed during the upgrade process?
camera operator | editor | production assistant
Mark Morache
on Oct 11, 2014 at 3:45:01 pm
It doesn't look like a rotation issue. In the before and after, the green swatch looks like it's in the same orientation, just a different scale.
Just a quick stab at a solution... in the video inspector for that green swatch, under "spatial conform", try going through your options, fit, fill and none, and see if any of those settings gets things back to where they were.
I'd be curious to see the animated swipe you're talking about.
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
Shaun Gilmer
on Oct 11, 2014 at 4:00:54 pm
Thanks for the reply. I tried unchecking everything, the only thing causing this it the rotation. Yes I scaled up everything in the final layer but it was always that way. Nothing else has changed. I experimented some and saved some of the compound clips that made up what I was rotating into an empty project, exported then dropped the new compressed clip back in to the same place. Worked perfect. This has been confirmed by people in another thread that the is a bug with how layers of multiple compound clips are handled in this version. This is going to be a pain for me in other old projects as well. They need to fix this.
