Need advice on how to ingest Sony .MXF
Paul Szilard
on Oct 4, 2014 at 9:08:15 am
Tried installing the Sony PDZK-LT2 program, but made no difference.
What is recommended conversion method to ProRes?
I have been looking at HandBrake, VLC and aPubSoft.
Thanks in advance,
paul
-apprentice-
joined 25 Nov 2012
platform OS X 10.8.2, MBP 15" late 2012, 16GB ram, 480GB SSD, TB Cinema Display, TB 2Big Disk 4TB
Jeremy Garchow
Re: Need advice on how to ingest Sony .MXF
on Oct 4, 2014 at 11:52:41 am
From what camera?
Mark Morache
on Oct 15, 2014 at 1:51:17 am
I recently had to do this in order to ingest xdcam footage from SxS cards.
I don't entirely remember specifically, but I installed a UDF driver, so my computer could see the SxS cards.
I also added drivers for XDcam codecs.
Then I installed XDcam Transfer.
Now I can plug an SxS card directly into my mac, and FCPX will see it and allow me to ingest the footage, rewrapping it so there's no needless transcoding. Very sweet.
I can also export mxf files out of our Sony media server, and use XDcam Transfer to rewrap the files to bring them into FCPX, again, without transcoding.
I remember it being a bit of a convoluted process to find all of these files, however once installed, everything is working file.
You can see which components you have installed by opening XDcam transfer, and under the help menu select "check for installed components".
Good luck
Don't live your life in a secondary storyline.
Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
