usb 3 in 2009 mac pro
Craig Alan
on Sep 27, 2014 at 5:39:33 pm
My understanding is there is no way to use a thunderbolt raid with an older Mac Pro (tower) Processor 2 x 2.66 GHz Quad-Core Intel Xeon Memory 28 GB 1066 MHz DDR3 ECC Graphics NVIDIA Quadro 4000 2048 MB
We use pegasus raids and OWCMETB7DH4.OT thunderbolt/ usb 3 raids in our studio and I need to bring projects or files home with me to the Mac Pro.
Would this be the best option
http://eshop.macsales.com/item/CalDigit/FASTA6GU3PRO/
Would this be as fast as the thunderbolt speeds I'm getting with our iMacs (2.8GHz Quad-Core Intel Core i7)?
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Oliver Peters
Re: usb 3 in 2009 mac pro
on Sep 27, 2014 at 7:02:27 pm
I've installed several of these cards with good success. You can expect speeds better than FW800 and about the same as eSATA. A lot of the performance will depend on the array, but I doubt you'll get performance as goos as through Thunderbolt.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Craig Alan
on Sep 27, 2014 at 7:14:27 pm
Good enough. Thanks.
Craig Alan
on Sep 28, 2014 at 6:41:19 pm
AVC-Intra 100 1080p60/30
3 camera multicam clips in FC. Will it be able to handle this?
An internal 2 drive software raid on the mac pro was able to handle it. Not super fast but I could edit the multicam.
But for projects I'm bringing to and from the studio this would get tedious.
Oliver Peters
on Sep 28, 2014 at 6:50:05 pm
Hmm... I would think (based on the numbers I've seen) that if your 2-stripe software RAID can do it, then the external USB3.0 drive would also be able to do it. Depends on the drive array itself, of course.
- Oliver
Orlando, FL
Craig Alan
on Sep 28, 2014 at 6:56:26 pm
http://eshop.macsales.com/item/OWC/METB7DH4.0T
what do you think?
Oliver Peters
on Sep 28, 2014 at 7:24:56 pm
Seems OK, but I have limited experience with OWC drives. The little I have had has been fine.
- Oliver
Orlando, FL
Craig Alan
on Sep 28, 2014 at 7:50:55 pm
well the pegasus drives work great but were three times the price at double the size. the owc seem to be working fine bout haven't used them with usb 3 since none of our computers have usb 3. i guess its worth a gamble for a $200 card since I have the drives already and need to go back and forth with projects.
Craig Alan
on Sep 28, 2014 at 6:58:20 pm
http://eshop.macsales.com/item/OWC/METB7DH4.0T/
I asked gary from an old thread too since he felt there were limitations to usb 3 in terms of software raids. and limited success from a lot of models.
John Fishback
on Sep 29, 2014 at 2:26:23 am
If the drive delivers the 500MBps it claims, it should work well enough.
Max Data Transfer Rate
Thunderbolt – Up to 10Gb/sec
USB 3.0 – Up to 500MB/sec
USB 2.0 – Up to 60MB/sec
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCP-X 10.1.3, Motion 5.0.7, Compressor 4.0.7
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Craig Alan
on Sep 29, 2014 at 4:01:30 am
I'll give it a shot. I bit more life out of the ole cheese grater.
