LUT Utility not working
Doğa Doğan
on Sep 19, 2014 at 5:41:42 pm
Hello everybody,
I just downloaded the LUT Utility for FCPX. Everything looked fine, but somehow the LUT options (Cinestyle S Curve, 2 Strip etc.) do not show up in the effects menu (see pic below).
What's wrong? I look forward to your answers.
Thanks in advance
Jeremy Garchow
Re: LUT Utility not working
on Sep 19, 2014 at 6:41:37 pm
Did you run both installers?
What version do you have (look in LUT Utility in system prefs)?
Doğa Doğan
on Sep 19, 2014 at 7:06:53 pm
Yeah, I did run both installers.
It says v1.44 in the settings panel.
Jeremy Garchow
on Sep 19, 2014 at 7:54:41 pm
And I assume you have restarted FCPX?
It's working just fine here with v1.44. I use it all the time.
The first part to install is the Apply LUT FxPlug, then install the LUT Utility for FCPX.
Doğa Doğan
on Sep 20, 2014 at 9:42:10 am
Of course I did!
How can I reset all the FCPX and plugin settings? Perhaps that could help?
Jeremy Garchow
on Sep 20, 2014 at 12:44:19 pm
First, in would wrote the folks at color grading central and ask about it.
Next, I would trash FCPX preferences by holding command and option and launching FCPX.
In your system preferences for LUT Utiility do you see a list of LUTs?
Doğa Doğan
on Sep 20, 2014 at 9:30:23 pm
I trashed the settings, however, nothing changed...
Yeah, I see all the LUTs in the settings app, but not in FCPX!
Apparently, other people have the same problem:
I really wanted to use this plugin, hope we can find a solution! :(
Jeremy Garchow
on Sep 20, 2014 at 9:38:49 pm
See if this helps:
Copy the following folders "CGC" and "LUTUtility" from:
Macintosh HD/Movies/Motion Templates/Effects/
to
User/Movies/Motion Templates/Effects
Doğa Doğan
on Sep 20, 2014 at 9:49:10 pm
I couldn't find any folder called "Movies" in the Macintosh HD directory.
Jeremy Garchow
on Sep 20, 2014 at 10:02:17 pm
Ok. That's good.
I'd try deleting the GGC and LUT Utility folders from User/Movies/Motion Templates/Effects and reinstall.
