Select all forward
James Ewart
Select all forward
on Sep 11, 2014 at 11:45:51 am
I still mis this tool. I understand Gaps helps out for pushing things along but what if you want to select everything forward of a certain point but what quick way of selecting everything forward if you want adjust volume for example?
Yes I can Shift select in the Timeline Index but it's a bit convoluted. Any thoughts?
Noah Kadner
Re: Select all forward
on Sep 11, 2014 at 12:16:14 pm
Lasso or Timeline Index are pretty much all you've got to work with.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
James Ewart
on Sep 11, 2014 at 12:27:54 pm
Such a simple little tool but so useful.
Bob Woodhead
on Sep 11, 2014 at 2:26:38 pm
Seems like for the times that I use it now, TL Index isn't too many clicks. I think I used Select Forward far more often in Legacy, where the advantage of using a mag TL wasn't available. As I recall, I usually used s/f to open up a gap in Legacy, or paste attributes. Much faster using a gap clip or clip searches in the index.
James Ewart
on Sep 11, 2014 at 2:56:56 pm
Yeah I agree. But today I miss it.
Bret Williams
on Sep 11, 2014 at 5:49:18 pm
Gotta agree with Bob. But you made a good point about audio, however I never used it for that. I don't even use a gap clip usually, because usually at the point I want to move things forward there's already a clip in the primary I can drag out. Then use the P tool and drag it back. No better or worse than legacy, just different. But actually, probably less prone to error. If you miss something in legacy or a clip gets deselected, etc. then you may not notice till it's all screwed up.
Why is it nobody ever misses "select all backward"? It just gets no love.
Bob Woodhead
on Sep 11, 2014 at 10:23:25 pm
Never look back!
