Back Up Libraries
James Ewart
Back Up Libraries
on Sep 11, 2014 at 7:09:11 am
Due to problems with Backups and having to disable it followed by a massive crash and apparent loss of everything now solved through reinstalling FCPX, I have noticed that the manually backed up library which I had copied to another drive would not open.
I believe this is because I renamed it having moved it (calling it backup).
Odd or not odd?
James
Lawrence Eaton
Re: Back Up Libraries
on Sep 11, 2014 at 1:01:30 pm
Do you have read/write permissions? Or maybe if you had to do a complete rebuild you are using a different user name?
Lawrence
