Getting multitrack audio out of MultiCam project possible
James Ewart
on Sep 9, 2014 at 2:41:05 pm
Does X2Pro solve this problem and allow me to export al 11 audio channels from my project in tact for mixing elsewhere please?
I've even tried copying and pasting all my synched tracks from the angle editor into a new project timeline but hat didn't help the situation much! (Thought it might have been a brilliant idea!)
James
Robin S. Kurz
Re: Getting multitrack audio out of MultiCam project possible
on Sep 9, 2014 at 2:54:07 pm
You'll want to read up on ROLES and how to export multi-track Quicktimes with them.
James Ewart
on Sep 9, 2014 at 2:58:38 pm
Thanks I thought I has but clearly need to go back again.
Jeremy Garchow
on Sep 9, 2014 at 4:29:24 pm
[James Ewart] "Does X2Pro solve this problem and allow me to export al 11 audio channels from my project in tact for mixing elsewhere please?"
Do you need all 11 channels or do you want all of your edited clips with handles?
James Ewart
on Sep 9, 2014 at 5:06:25 pm
I'd really like the lot ideally to give to somebody to try and make some kind of decent mix of all of it. Might be able to narrow it down to 8.
best
James
Jeremy Garchow
on Sep 9, 2014 at 5:07:24 pm
Then X2Pro is probably what you want.
James Ewart
on Sep 9, 2014 at 5:23:50 pm
Thanks Jeremy.
I'm playing with roles and sub roles seeing if that can get it out but if X2pro can "find" my audio, keep it in sync and output it as wav or aiff files then that's probably best.
Jeremy Garchow
on Sep 9, 2014 at 5:25:12 pm
To be clear, X2Pro presents all of your clips as edited in an AAF container for use in ProTools.
It doesn't make traditional aiff or wav files.
Jeremy
James Ewart
on Sep 9, 2014 at 6:05:30 pm
but all tracks/channels in their entirety in sync?
thanks
James
Jeremy Garchow
on Sep 9, 2014 at 6:10:06 pm
It will mirror your edit, yes.
