Massive FCPX Project
Joshua Moise
on Sep 5, 2014 at 12:57:28 pm
Hi there,
I'm wrapping up a feature film I cut on FCPX and the project has become completely unwieldy at 533 GB. It's so gigantic that occasionally it takes twenty minutes to load.
How do I make FCPX projects smaller? I've already deleted unused render files and it only took off a relatively small amount of data.
Josh
Nikolas Bäurle
Re: Massive FCPX Project
on Sep 5, 2014 at 2:06:39 pm
You could consolidate the project:
http://support.apple.com/kb/PH12706
"Always look on the bright side of life" - Monty Python
Jeremy Garchow
on Sep 5, 2014 at 2:16:47 pm
What version of X?
James Ewart
on Sep 5, 2014 at 2:44:51 pm
And which Mac are you using please?
Joshua Moise
on Sep 5, 2014 at 3:01:09 pm
Using the newest version of FCPX. OSX 10.9.4
Jeremy Garchow
on Sep 5, 2014 at 3:14:56 pm
Are you using Proxy media? Where's your cache stored? Where your optimized media stored.
A few more details about how set up the Library might help.
Where is your Library located (what kind of drive)?
Joshua Moise
on Sep 5, 2014 at 3:19:42 pm
All the media is on one hard drive. I did not use optimized media, so I think it's referencing proxy files or the raw media itself. All the other files are located within the library file that's so huge. It's on a Glyph Thunderbolt drive.
J
Noah Kadner
on Sep 5, 2014 at 3:46:21 pm
Yeah I'd back it up and then Consolidate it.
Noah
FCPWORKS - FCPX Workflow
Call Box Training
Jeremy Garchow
on Sep 5, 2014 at 4:15:21 pm
[Joshua Moise] "All the media is on one hard drive. I did not use optimized media, so I think it's referencing proxy files or the raw media itself. All the other files are located within the library file that's so huge. It's on a Glyph Thunderbolt drive."
Single click the Library and open the inspector (command-4).
In there, you should see where the media is located, and how much space it is taking up on your drive.
It should look something like this:
Craig Alan
on Sep 6, 2014 at 5:04:43 am
What codec is it in? You might need to optimize.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Craig Alan
on Sep 6, 2014 at 5:02:15 am
500 gb is not massive. Get a thunderbolt raid. Check out owc if u can't afford a Pegasus. A single drive is not going to cut a feature w comfort. And max out your ram. Make sure to leave a lot of headroom on your media drive. Past 75% or so will slow things down.
