10.1.3 log processing
Mark Steele
on Aug 27, 2014 at 2:41:21 pm
I have just upgraded to 10.1.3 and my "log processing" has disappeared.
Has anyone encountered this? Someone else has 10.1.3 and they have no problem..
Should I reinstall 10.1.3 and if so how do I do that? The app store has me as upgraded already.
MARKSTEELEPRODUCTIONS.COM
Jeremy Garchow
Re: 10.1.3 log processing
on Aug 27, 2014 at 4:05:51 pm
[Mark Steele] "I have just upgraded to 10.1.3 and my "log processing" has disappeared."
Log Processing happens from the Browser only. Are you trying to set it in the timeline?
If you are trying to turn it on in the Browser, make sure "Settings" view is chosen in the Inspector Info tab. It is the drop down on the left.
Jeremy
Mark Steele
on Aug 27, 2014 at 4:37:18 pm
FCPX crashed and when it restarted the log processing was there.
I've found that you can apply the processing in the project timeline but it is applied to all the instances of that clip, as it should.
Jeremy Garchow
on Aug 27, 2014 at 4:58:06 pm
[Mark Steele] "I've found that you can apply the processing in the project timeline"
Hmm, that must be new to .1.3, or perhaps I was mishandling .1.2
No matter, glad you're up and running!
Simon Blackledge
on Aug 29, 2014 at 4:39:53 pm
It's just a shame it's a PRE process..
So LOG process > Clipped > CC .. :(
Jeremy Garchow
on Aug 29, 2014 at 6:37:19 pm
I tend to use LUT Utility for this, anyway.
http://www.colorgradingcentral.com/lututility
