C100 Audio in FCPX Grey
Andrew Ng
on Aug 27, 2014 at 9:43:30 am
This is a huge headache (possible bummer).
I've imported my c100 footage.. only one of the three videos I imported has the audio working correctly.
The other two seem to have greyed out and inaccessible audio tracks.
I've tried clicking around to see if I could separate audio tracks.. even tried reimporting and separating audio tracks... no luck.
What's interesting is that these two clips seem to have unique audio meters... so the audio must be SOMEWHERE? Note, all three clips were captured with the same settings on the camera. I used a Senheiser wireless lav... receiver going into Ch1 of C100. I verified meters on the C100.
Thank you in advance for your time and support. Happy to provide further information if it helps.
Troubled Clips
Clip with correct audio
Jeremy Garchow
Re: C100 Audio in FCPX Grey
on Aug 27, 2014 at 4:19:27 pm
Those clips come in flagged as stereo, it seems, and id there's only one channel of audio, that may not be correct.
Try changing the "Stereo" drop down to Dual Mono in the inspector and see if that helps.
Jeremy
