FCPX 10.1 and sparse disk images for archiving
jim bachalo
on Aug 23, 2014 at 1:54:49 pm
Watched this great tutorial on using sparse disk images to archive completed projects
Is this still a valid technique with the latest FCPX 10.1? What has me confused is that in the video when he chooses Duplicate Project he is presented with a pop-up that allows a destination to be chosen. To accomplish the same thing now what would be the process?
You should follow me on Twitter here. My latest work
Ronny Courtens
Re: FCPX 10.1 and sparse disk images for archiving
on Aug 24, 2014 at 8:50:15 am
Using sparse disk images for archiving was a good solution when Event and Project folders were separated. Now that everything is already contained inside a Library there is no real need for this anymore. Just clean up your Library (delete Generated Library Media Files if you wish), make sure all your media are consolidated and archive the Library.
- Ronny
