create individual sequences from favorites?
Jason Brown
on Aug 21, 2014 at 10:24:11 pm
Any way to quickly set multiple in/out's on a clip and generate individual sequences for each range? (or "projects" as they are incorrectly referred to) :)
Charlie Austin
Re: create individual sequences from favorites?
on Aug 21, 2014 at 10:49:48 pm
Create a new project, set favorite ranges, select all, hit Q or D to cut into project.
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Jason Brown
on Aug 21, 2014 at 10:54:08 pm
I'm not sure you understand. I have 15 favorite ranges...want 15 sequences.
Charlie Austin
on Aug 21, 2014 at 10:59:36 pm
[Jason Brown] "I'm not sure you understand. I have 15 favorite ranges...want 15 sequences."
Ah... I think you'd have to do each individually then.
You can right click the favorite and make a new compound clip, but at some point you'd need to cut 'em into projects and break them apart. you can edit in a Compound clip just like a regular project, but it's not the best idea....
Jason Brown
on Aug 21, 2014 at 11:27:27 pm
Hmmm...if I can share a compound clip, it might work. I'm trying to export pieces of a digitized tape.
Charlie Austin
on Aug 21, 2014 at 11:37:01 pm
[Jason Brown] "Hmmm...if I can share a compound clip, it might work. I'm trying to export pieces of a digitized tape."
Oh.. that's easy, just select the range and share it via the share button or menu. :-)
See this thread for more info... http://www.fcp.co/forum/4-final-cut-pro-x-fcpx/21050-batch-export-favorites
